BeoLab 18 vibration noise
splud
Posts 24
splud Posted: Sun, Nov 29 2015 2:01 AM
Hi Guys,
Not sure if anyone can help? But one of my Beolab 18's has started to make a really bad noise when a strong bass is played mainly in movies, it's like a vibration noise from the air intake, hard to explain. I've tried tightening all the screws and also with and without the cover.... I've had them for about 2 years so out of warranty probably.
Cheers TC
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Nov 29 2015 2:25 AM
Hi TC,
All B&O products come with a three year warranty, and the BL18 was launched in late 2013 so will undoubtedly still be under warranty.
The best course of action therefore would be to contact your dealer and see how they want to proceed, but please do let us know the outcome once you know what the problem is/was.
Kind Regards,
Martin.
splud
Posts 24
splud replied on Sun, Nov 29 2015 2:39 AM
Ok Thanks, I didn't know about the 3 year warranty. I'll keep the forum updated.
Cheers
TC
Beo80802
Posts 2
Beo80802 replied on Fri, Sep 28 2018 2:04 PM
Hi TC,
i am owning a pair of 18s (got them new from the dealer)  and i realized same problem you´ve explained.
Could you please tell me what was the issue?
Thank you very much and best regards
Kai
splud
Posts 24
splud replied on Sat, Sep 29 2018 1:43 AM
Hi Kai,
We had to take them to the B&O repairer, which fortunately we just managed to get under warranty. I think from memory it was the bass driver? Sorry I cant be more help, good luck! :)
TWG
Posts 1,672
TWG replied on Sat, Sep 29 2018 7:33 AM
- if it's a rattling noise like there's some small part shaking/moving it will be the bass driver and its coil.
- if it's an air/wind flow noise type sound, it's just the noise the air makes while being pumped through the bass reflex tunnel. Simple physics and nearly inevitable on very very high volume levels. At normal listening levels it shouldn't be audible!
Page 1 of 1 (6 items) | RSS
