iTunes on Beosound Moment
This post has 40 Replies | 1 Follower
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Dec 30 2015 7:13 PM
Carolpa:
Apple does not support DLNA. That could be the reason why Twonky doesn't work properly combined with an ATC
Hi Carolpa,
I’m not answering you in person, because the next you will definitely knowing.
You'd have to install some software to be able to stream via the DLNA protocol. Apple doesn't support it 'out of the box'.
Apple has never signed to be a member of the DLNA family, so their products are not certified.
Out of experience, using an ATC or Extreme will have some concerns with Apple compatibility affecting DLNA capability. Twonky Server as a DLNA/UPnP compatible media server or any other works, but not stabile over a long time. Apple has there own protocol AirPlay which is an alternative to DLNA.
Even the well known Linn media products are advising not to use Apple routers, strange B&O doesn’t advise their customers.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Page 2 of 2 (41 items) < Previous 1 2 | RSS
DigiCert Secured Site Seal
