I am trying to find a diagram or instructions on how to replace the door/cd drive belt on the besound 2000 i have the speaker grill off and can see where the new belt goes just wondering if anyone had any info on the easiest way to replace it. I have an idea of how to do it but before i start thought i would see if i can get some good advice on this first.
Thank you for any help in advance
Taylor T.
Beosystem 4500 With Beogram rx2
Beomaster & Beocord 3300
Beocenter 9000
Beosound 2000
Beolab 6000
Rl 140 & Rl 35
Beovox S75
Having disengaged the lever that operates the clamper, I drive the rubber band through the mesh of the two plastic cog wheels!
Neither the rubber band or the plastic cogs are damaged.
I don't know if this is recommended by B&O 'cos it seems to be omitted from any service manual that I have read. It works for me.
No doubt someone will say it is bad practice but I am all ears for a better way that does not involve several hours of stripdown.
Regards Graham
Well got my belt in and after about 30 mins of carefully and scared shaking hands turns out it is very very easy to do your self just gotta remember where everything goes i took some pics of the inside if anyone ever needs help or to see what is involved to changing the belt. Saved me $99 to change my self very happy more money for parts for other B & O products lol
joeyboygolf: Having disengaged the lever that operates the clamper, I drive the rubber band through the mesh of the two plastic cog wheels! Neither the rubber band or the plastic cogs are damaged. I don't know if this is recommended by B&O 'cos it seems to be omitted from any service manual that I have read. It works for me. No doubt someone will say it is bad practice but I am all ears for a better way that does not involve several hours of stripdown.
for someone reason it looked like it was going to break my belt if i did it that way or maybe my inner self wanted to strip it down for fun lol
Hi There I am looking to replace my belt and would appreciate any help you could give me.
cheers Roger
do you know the size of the belt?
Belt can be found here.
