S45-2's woofer magnets
This post has 3 Replies | 2 Followers
jclabburn
Posts 2
jclabburn Posted: Tue, May 3 2016 10:15 AM
Hi All,
One of my S45-2's has developed the dreaded 'seized woofer' issue as the magnet has separated.
I can find a few really good discussions about this but only one hands on remedy (the excellent post about using a CD case and various other bits to reposition things before re-fixing).
Doe anyone have any more info or step by step guides for the fixing process please? I would love to know the detail of things before I jump in there and get my hands dirty.
Lastly... is it really a repair job? Some have said that replacement is the best option.
Many thanks for assistance!
Jonathan,
HELSINKI
Bristol603
Posts 50
I am sorry to say that I believe you will struggle to find a replacement S45-2 woofer other than cannibalising another working speaker. I have done this repair and it was fine. Take your time and enjoy bring it back to life. Good luck.
PS - it may be advisable to apply some prophylactic epoxy glue around the magnet on your surviving woofer to stop it also slipping.
Bristol603
Posts 50
jclabburn
Posts 2
Hi and thanks for the reply Mr Bristol!
Can you give me any tips int he repair and do you have any photos of the process please? I am pretty technically proficient but realise that this is a fine tolerance exercise where permanent damage might be a result.
Any step by step guides would be a great help.
Cheers,
Jono
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
