Hi guys,
I've got a strange question for owners of the Beoplay H6; does your headband have a couple of ridges / creases on the leather, right at the part where the cushioned section starts on each side? If you run your fingers over the leather, can you feel the ridges?
I got a pair of Beoplay H6 in grey hazel from a company on eBay, the condition was noted as "new - other", which according to them means unused but damaged packaging, but mine has these small creases on the leather and I perhaps I'm being paranoid but I can't help but wonder if they've developed from use, or if they all come like that.
Same here. I've never noticed it before, but I had to check and there are indeed some small ones. Barely noticable, though. The ridges get more pronounced when I pull the headphones apart, like you do when putting them on. My H6 is 2,5 years and see a lot of use daily.
-h.
Thanks guys.
On the one hand I'm glad to know it's not a defect as such (or at least, not peculiar to my model), but on the other I'm no wiser as to whether this is the result of use! Maybe I'm being picky, but after all the reviews talking about the luxurious construction I guess I wasn't expecting imperfections out of the box.
I have a pair of rarely used, limited-edition, dark green H6s that may have the "defect" you describe. Based on how little I've used them, I'm going to say this is "as designed"... although, I would categorize it as a very slight dimple in the stitching vs. a ridge so perhaps it gets more pronounced with use. Either way, I never noticed this, and it took me a few minutes to find this even with your description. Enjoy the sound, leather is meant to get a little irregular over time.
Stan
Perhaps I'm being picky. I can get a bit fussy about imperfections, but maybe mine exhibit this a little more than others as I noticed it straight away. If I run my fingers along the band, I can feel quite a bump in the areas affected. Now I know they are there, I won't stop thinking about them! I probably just need shut up and enjoy them
cds:I probably just need shut up and enjoy them
