I have a smaller bedroom and have to choose between a set of Lab 3's or Lab 17's wall mounted and connected to an essence.
I have a pair of lab 3's (with a Lab 2 as subwoofer) but have never heard a pair of 17's.
If anyone has compared both which do you think sounds better? (I could potentially add a sub but it would have to be a small 17 as a lab 2 is too big and a lab 19 is too expensive.
Music listend to is pretty much all around, jazz, rock, popular, classical etc..
Any help from speaker aficionados much appreciated.
Best
P
PS
The other thought I had was to use a pair of Beoplay S8 BUT I am not sure if it plays nicely with an essence as it is primarily marketed as TV speakers and doesn't seem to have power link in
phult:I have a smaller bedroom and have to choose between a set of Lab 3's or Lab 17's wall mounted and connected to an essence. I have a pair of lab 3's (with a Lab 2 as subwoofer) but have never heard a pair of 17's. If anyone has compared both which do you think sounds better? (I could potentially add a sub but it would have to be a small 17 as a lab 2 is too big and a lab 19 is too expensive. Music listend to is pretty much all around, jazz, rock, popular, classical etc.. Any help from speaker aficionados much appreciated. Best P
I've owned them all. First of all, I'd take out the S8. It's not nearly as good as either the 3s or 17s.
The 3s are excellent for their size. I would agree, lacking a little mids, but impressive sound. A little complicated to set up with all the wires. With the 2 sub, a complete system that gets loud.
The 17s are great on their own. Lots of bass (not nearly as much as the 2, but more than the 18s) and fill a room. Super simple setup with WISA. A little crisper highs. I have a pair currently.
All in all, sound wise, I think the 3/2 combo sounds best. The 17s will simplify your life and sound great.
17's. A vastly underrated and overlooked speaker.
The 3's are good, don't get me wrong - but if you've ever seen the size of the bass driver on the BeoLab 17 you'll understand just why they sound so punchy!!
WISA too.
As I said though, this is a comparison of excellent versus excellent and a bit more. You won't regret either.
Lee
Austin:The 17s are great on their own. Lots of bass (not nearly as much as the 2, but more than the 18s) and fill a room. Super simple setup with WISA. A little crisper highs. I have a pair currently.
Wow! So much love for the 17's. Good to hear... seems like B&O's "under the radar" speaker standout, sort of like the Beolab 4000s of their day.
