I recently purchased a pair of S75 and I would like to change the capacitors however I am having trouble finding out what capacitors I would have to buy.
I am pretty sure these are the capacitors that are on the crossover I am however not completely sure. I also don't know if these are polarized or all bipolar capacitors.
If anybody knows a bit more about the capacitors I would much appreciate some input.
Welcome to Beoworld !
Capacitor kits are readily available for most Beovox models, including Beovox S75.The kits contain correct components, values and types and comes with a detailed component location chart.Email or PM me.
Thanks for the reply, I would like to just buy a kit however I am on a pretty tight budget for now and would like to at least get the S75 in working order. I really just need to know if the capacitors are all bipolar or can all be replaced with bipolar capacitors. I am pretty sure that a lot of the original aren't bipolar however when I read a few topics on this site I get the idea that they are all bipolar. So that is why I am asking.
Grabbing a kit is often cheaper than finding and buying the components separately.All caps in your filters are axial, bipolar electrolytics (the speaker lead signal is AC).Make sure to get capacitors of a decent quality, meant for crossover applications and preferably 100V types.
Hello, i've just bought a pair of s75 without crossovers but with good speakers. I'd like to restore them, but i can't find the crossovers schema.
More, could you please tell me how much would cost me one of your complete kits for that?
Thank you !
Are the filter boards missing?
Yeah, it doesn't remain anything.
I suggest you look for a pair of original filter boards before thinking about the capacitors.Caps is the easy part. There are many other components on those boards besides caps.
Thanks for the advice. By luck, I just found the schema, but i'm not sure between the tweeter and the dome medium. Could you please tell me who is who? I try to insert a picture...
No way! Could you please tell me the colors of the wires on each speaker? It would be agreat help...
Hello
i’m looking for a caps Kit for my S75
Do you still sell it ?
thx !
BenS75: Hello i’m looking for a caps Kit for my S75 Do you still sell it ? thx !
Yes.I have answered your email.
Martin,
I am also looking for an S75 Cap kit (and resistors) if possible. However I am in the US.
I posted this question in another thread but is there a mod or fix for the overheating/burning resistors?
Rings a bell
Jacques
Elgato: Martin, I am also looking for an S75 Cap kit (and resistors) if possible. However I am in the US. I posted this question in another thread but is there a mod or fix for the overheating/burning resistors? Thanks
Capacitor kits and resistors are in the webshop.Beoparts-shop
