Beosytem 5500
Stui23
Posts 5
Silver Member
Stui23 Posted: Sun, Dec 18 2016 12:26 PM
Hi All. I'm new to Beoworld as I have just bought myself a 5500 set up and thought it would be useful to join. The only "odd man out"  is that I have the CD50 instead of the CD5500. The problem is that I cannot control the CD50 from the 5500 master control. I'm not sure if it's a problem with the amp or the CD player, or if it's a known problem with the connecting leads? The amp is receiving a signal from the MCP as the rest of the system works ok. i.e. tape and turntable.Can anyone help please?
Thanks all.
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Dec 18 2016 12:49 PM
First of all, check that the connecting cable has all seven pins (at both ends, if it is detachable at the CD end).
Welcome and thanks for joining as silver!
--mika
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Dec 18 2016 2:50 PM
tournedos:
Yes, Mika is right, because it should work. Mine does in the same configuration!
You can't use RCA connectors for remote operation, but you must use (much better imho) DIN cables.
Jacques
Stui23
Posts 5
Silver Member
Stui23 replied on Sun, Dec 18 2016 4:48 PM
Thanks for the welcome, and thanks for the replies. I have checked the DIN cable and all 7 pins are present both ends. I have also checked continuity through all 7 pins and all is well, so now I'm stumped! I'm thinking now that it is probably the CD50 at fault. Any other thoughts please? Buying used equipment is always a risk as you never know it's history. I bought all of it of Ebay from 3 different people as well, not as a complete system.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 18 2016 6:32 PM
It does play though? If you control the CD50 manually?
Peter
Stui23
Posts 5
Silver Member
Stui23 replied on Tue, Dec 20 2016 10:19 PM
Yes it works perfectly from the front controls
Page 1 of 1 (6 items) | RSS
