50Hz on alu part of speker body- why ?
This post has 8 Replies | 0 Followers
marexy
Posts 710
marexy Posted: Mon, Jan 9 2017 1:40 PM
When a finger-palm of my hand is drawn across speaker alu part i feel 50Hz electrical frequency  on my BL 12.3
What is wrong?
The same may be felt in the BL 4000 on aluminum part of the speaker.
Seanie_230
UK
Posts 2,278
Hello there
I get this on every piece of B&o I own every time I touch the ALU i get a buzz, for me its worst on my BLGW and zaps me more than my speakers or TV
If you find a solution please let me know.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
CB
> You are Here <
Posts 1,762
CB replied on Mon, Jan 9 2017 2:27 PM
Hello,
I think it's the same as what was described here
For me, it's a grounding lack/ issue...
marexy
Posts 710
marexy replied on Mon, Jan 9 2017 3:42 PM
Hi
I'm know some stuff ..and when i connect all devices in line on  phaze and null to correct position it's 50% better :)
Seanie_230
UK
Posts 2,278
Can you please explain?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
marexy
Posts 710
marexy replied on Tue, Jan 10 2017 7:00 AM
Try to reverse each of main cable of the BL speaker one of the time. phaze- null than revers ....null phaze ..
At the same time it has to be connected to B&O device via PW cable.
i do not know why ..sometimes it wotk's for me.
It has to be some grounding issue :(
Nobody till now can explain to me why ..or how to fix it :(
Starbug
Posts 2
Starbug replied on Tue, Jan 10 2017 7:16 AM
Hello i read in the Installation Guide for the Beosound Moment about the same problem. There is a workaround for grounding over the Powerlink socket. I don't know if it is also possible for other products. But this prevent the ticking feeling. Sorry for my englisch. It is not my nativ speeking.
marexy
Posts 710
marexy replied on Tue, Jan 10 2017 7:30 AM
Hi
Thanks ..it's the same problem i think :(
 is these it ?
http://www.bang-olufsen-rivierenland.nl/wp-content/uploads/2015/04/30472829.pdf
Starbug
Posts 2
Starbug replied on Tue, Jan 10 2017 7:45 AM
Yes this is the workaround i was talking about.
Jonas
Page 1 of 1 (9 items) | RSS
