I believe mine still works. Only I use it for Deezer exclusively, have no files stored locally.
AnalogPlanet:I believe mine still works. Only I use it for Deezer exclusively, have no files stored locally.
Mikipidia: hasn't the mood wheel more or less stopped working? There seems to be a whole thread on it. and I was under the impression the moment doesn't have a bl90 preset either...
I know Miki, I know - I know the whole (sad) story of the BS Moment.
Back then I knew a guy, who was betatesting the Moment, and I had the opportunity to play with it.
And I participated heavily in the discussions on the forum in those early days.
You should not compare these two ‘concepts’ directly.
Let an iPad with AP2 be what it is - it will never come close to what was intended with the BS Moment.
Hardly anyone wants the BS Moment today.
There are other solutions, but they aren’t doing, what B&O had in mind with the Moment back then.
Trying to make the Moment a fully fletched, genuine DLNA player (accessing large NAS-based collections) turned out to be a failure.
And then came the problems with the jukebox/the tablet part hardware.....
Today it suffers by the missing Gracenote support.
But apparently there is hope, that B&O will bring out a new SW and that they are facing the ‘Gracenote problem’....we’ll see!
Here is a link to the original explanation of the BS Moment concept - by Lyle Clarke - from 2015
https://youtu.be/pdCXwuWv0qE
IMO, the right way to use the BS Moment, is to use it as what it was originally intended for...........a music player - basicly founded on a Deezer and a TuneIn subscription - that plays what you like, learning what you like at a given point of the day.
It is a ‘one-touch-music-machine’, which is what a lot of people want!
The iPad/AP2 combo is something else - and the right solution for some people.
Personally I’d also choose an iPad-based solution against the BS Moment concept. But that is because I am an (old fashioned) dedicated album listener, who prefer to choose exactly, what I want to listen to, when I listen - I am not a friend of ‘automated music listening’.
I don’t see a place in the portfolio of B&O for the BS Moment.
Rather I see that B&O could take this concept of simplicity to a next, a higher level in - maybe - some sort of new audio player, a new BeoSound.
Millemissen: Trying to make the Moment a fully fletched, genuine DLNA player (accessing large NAS-based collections) turned out to be a failure. IMO, the right way to use the BS Moment, is to use it as what it was originally intended for...........a music player - basicly founded on a Deezer and a TuneIn subscription - that plays what you like, learning what you like at a given point of the day. It is a ‘one-touch-music-machine’, which is what a lot of people want! But that is because I am an (old fashioned) dedicated album listener, who prefer to choose exactly, what I want to listen to, when I listen - I am not a friend of ‘automated music listening’.
I use iTunes, so all music is available via iTunes Match. I can also use the recommendation for me as well as choose a mood-oriented playlist from Apple Music. On the iPad, I can choose from Spotify, Apple Music and use Siri and Siri shortcuts to easily access any content or service. Not sure how much the Moment costs, but you can get an iPad for $299 and it will give you access to more content. AirPlay 2 is also lossless and plays nice with a wider range of systems - not just B&O.
Since the OP was using an iPad to stream content, my point is that the Moment does not add any real value. OK. I didn't think about the mood wheel (?). Is that all that makes it into an Apples to Pear comparison?
B&O in my life 😊:
I agree with everything you just said here :)
If i want to use the Moment like a BeoSound 5, not connected to the Net and only with music stored in the BeoMaster 5 with embedded covers, it’s OK?
Steph:If i want to use the Moment like a BeoSound 5, not connected to the Net and only with music stored in the BeoMaster 5 with embedded covers, it’s OK?
