Extending 7-Pin DIN Cable
This post has 9 Replies | 1 Follower
AnthonyJan
Posts 7
AnthonyJan Posted: Thu, Mar 30 2017 6:39 PM
I need like 3 more feet for my BeoGram 3000 Record Deck to reach the Beomaster 3000 receiver.  I don't want to cut the cords and solder for extension.  Is there a female 7-PIN to male 7-PIN connection out there that will work for that application?  I don't seem to be finding any online.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Mar 30 2017 6:49 PM
The cable is double-shielded and extending it is generally not recommended due to the signal level and the amount
of amplification that follows.
I know of no 7-pin DIN extension cables, but the extension needs to have both shields too - separate like in the original cable.
Saint Beogrowler
Saint Paul
Posts 780
I'm using an B&O Aux expander as a short extension right now but I'm using it for a Beocord that will have more output than a Beogram.
Saint Beogrowler
Saint Paul
Posts 780
On second thought, sometimes I'll run a 7pin din loom from Sounds heavenly that allows the addition of an external preamp and also datalink capabilities. That will give you the 3 feet you need without sound degradation.
Millemissen
Flensborg, Denmark
Posts 14,680
AnthonyJan:
There is - or maybe there were.
I am using one with my BeoGram 4500, but I am not sure that you can buy these (new) anymore.
And then there is the socalled ' cigar-solution' - a small female/female coupler to add another male/male cable.
Not sure that you can get hold of that one either.
Why not ask Steve at SoundsHeavenly for help!
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Mar 30 2017 11:37 PM
Millemissen:
AnthonyJan:
You can do it with your BG 4500, Millemissen, because it has build-in RIAA amp. The problem with the BG 3000 is, that it does not have RIAA - so the signal is much weaker, and it can cause some problems if you extend the cable.
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Mar 31 2017 9:52 AM
I tried using an extender cable once and had hardly any sound - only way is to use a preamp on the turntable and then run a lead - but that would mean not being able to use the Phono input on the beomaster and no remote control (unless you get Steve to make a lead up)
Andrew
Frinton, UK
Posts 917
Andrew replied on Fri, Mar 31 2017 9:54 AM
Just re-read the post 3 foot should be ok to extend - I would ask Steve.
Saint Beogrowler
Saint Paul
Posts 780
You also could do an 8pin din extension and break the center male pin
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Yes, I will be pleased to build Beogram extension cables with the correct shielding.  For earlier Beograms like the 3000 which don't have a built in pre-amp, then I would always suggest trying to avoid the need for an extension if possible, or alternatively considering using an external pre-amp near to the Beogram if a long extension cannot be avoided.  However, short extension cables don't usually give any loss of sound quality when properly constructed.
For later Beograms like the 4500 that have a pre-amp built in, you can safely extend the cable up to 20 metres without any issues.  However, correctly shielded cable should still be used, standard 7 pin DIN Aux cables or 8 pin Powerlink cables are not usually double shielded for use with Beogram turntables.
Please feel free to get in touch via my sponsor link below if you would like any help with cabling.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (10 items) | RSS
