BeoRemoteOneBT with an ir-based BV - anyone?
This post has 6 Replies | 2 Followers
Millemissen
Flensborg, Denmark
Posts 14,680
Millemissen Posted: Mon, Apr 24 2017 11:11 PM
Is anyone using the BT version of the BROne - of course set to ir-mode - with their BV11/V1/Avant2014?
Any advantages or disadvantages over the regular BROne?
TWG
Posts 1,672
TWG replied on Tue, Apr 25 2017 10:57 AM
Does the Beoremote one BT operate in a mixed mode, e.g. Audio Bluetooth and Video infrared?
Millemissen
Flensborg, Denmark
Posts 14,680
No, not that I know!
You will have to switch every time you change, which is uncool ;-(
However my question is, how it behaves when set up to be only used with ir-based products compared to how the first BROne does.
One difference is that it has 4 MyButtons.
TWG
Posts 1,672
TWG replied on Tue, Apr 25 2017 11:22 AM
Millemissen:
That is indeed VERY uncool and not thought-out. :-(  Maybe Bang & Olufsen can sort this out with a software update.
I understood your question and I know the visual differences but I can't answer it; sorry.
Does the Beoplay Range (A1, A2, A15, A17...) accept the Bluetooth remote, too?
Ralf
Hamburg Germany
Posts 189
Ralf replied on Tue, Apr 25 2017 11:45 AM
I have both the BT and IR only version of the BRone.
They work exactly in the same manner.
I like the BT more, because the keys are a bit more ergonomical, channel switch and volume control are much better to touch and easier to reach.
You do not have to switch between IR and BT, you just have to choose the product, e.g. Beo4AV, so it is not a great thing to control other devices.
The BRone does not work with M5, A6 or other Beoplay products. Pairing fails, my dealer told me, that a proceeding software update for  Beoplay  may support the BRone. The essence BT remote works great with M5 and A6.
I could pair the BRone with my smartphone, but i found  no useful interaction yet. I supposed to control the Beoapp or Music App, but  this did not work.
Ralf
TWG
Posts 1,672
TWG replied on Tue, Apr 25 2017 12:10 PM
Ralf, do you have to switch the modes or can you e.g. save one Beo4-IR-product on a "my button" and a Bluetooth product on another "my button" without any configuring/switching?
The Beoremote One BT would be a nice remote for the portable High resolution audio players from Sony, Pioneer, Astell & Kern, Teac, Onkyo etc. at home!
I've tested an Essence remote with a Sony NWZ-ZX1 and it works fine. If you use those players in a docking station the remote is a must.
Sandyb
Posts 2,186
Sandyb replied on Tue, Apr 25 2017 2:35 PM
You have to change the product you want to control from the remotes menu...........if you chose a BeoVision from the list (11/14/BS4) it switches to IR mode, and it won't talk to the newer TVs, and vice versa..........one advantage of the newer remotes is the 4 myButtons as opposed to 3......when the BT remote is in IR mode, it seems to work in the same way as the regular BR One, for example allowing management of sources that show under TV / MUSIC.....which you can't when using it in BT mode with the newer TVs, where that list management is done on the TV........
i don't see much difference between the ergonomics of either, the newer one marginally better i guess.....but is a 4th button really that important?
Page 1 of 1 (7 items) | RSS
