BeoSound Ouverture - No sound through all sources
This post has 3 Replies | 3 Followers
Dany
Posts 8
Dany Posted: Sat, Jun 24 2017 9:10 AM
Hi Guy's
I've got Ouverture with interesting issue. There's no sound on any sources. Powerlink shows all functions like source, volume etc, beosound is playing anything on all sources (CD, Tape, Radio), but there's just silence on powerlink and headphone jack. Muting seems to be fine. Beosound is on Option 1.
I've checked all connectors between boards, but I've no idea where is the problem. Any hints?
Regards!
SvenO
Posts 3
SvenO replied on Fri, Mar 20 2020 6:01 PM
Hello folks
i have the same issue. i used the device for like half a year and it worked quite well, except the above described issue for like 2-3 time. now, i had it unused for like a month. today i plugged in all the cables and wanted to use it, but no sound at all ! any ideas? any help is highly appreciated. is there maybe a way to do like a factory reset? cheers, sven
SvenO
Posts 3
SvenO replied on Sat, Mar 21 2020 7:13 AM
now, i have to say that i just have the standard "BeoSound Ouverture, Type No. 2631, Sw 2.1" with the standard speakers. Is it maybe possible that I adjusted something wrong with this remote control? Everthing is working fine, even the mute function (lights go red on both speakers) and the device did work well a long time.
So if it would be broken, can I anyhow still use the speakers?
Cheers, Sven
DMacri
United States
Posts 881
DMacri replied on Sat, Mar 21 2020 9:00 AM
It sounds like some circuit responsible for both audio channels has failed. The speakers can be used as just stand alone Beolab 2500 using the powerlink input.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
