hope you can help, as my wife missed firsepisode of downton abbey, i downloaded on to my laptop from itunes, any way volume at maximum and could only just hear it through the laptop speakers do i have tohave special cable. played a sample music tune fom i tunes sound ok.
malcolm
Hi Malcolm,
Highlight your film in iTunes library, right click to get info. Fourth setting there will be 'Options' click on it and you will see a volume slider, set up to maximum and press ok :)
Hi Paul
Many thanks for the info,worked a treat
That's awesome! There's also a setting in preferences in iTunes called Sound Check - that sometimes increases the range too!
There are 3 volume levels that are combined:
- Your computer's volume
- iTunes volume
- iTunes equaliser
Make sure all are at the max. Otherwise ask for a refund, by clicking on "Report a problem" in the invoice you got from apple.
Beoworld app with direct photo upload and emoticons.
