With two BL5 connected to BV11, does it really matter in which position the left/right switch at the speakers are set?? The manual states so "remember to etc". But isn't it sufficient to adapt it on the sound menu of the BV11, ie there one can choose whether its left or right? Or am I missing something ?
thanks, Rene
Each Powerline carries both L and R signals. These are controlled from the BV11 Sound settings.
Thus as you flick the L/R/(line) switch, the white noise remains the same
hence they just need to be in different positions - but no harm if the physically positioned to the left speaker is switched on the BL5 itself in the "right" position but in the BV11 menu being defined as "left" ????
BeoNut since '75
