Beovox Cona
Nettan49
Posts 2
Nettan49 Posted: Mon, Jan 29 2018 4:20 PM
Hi!  I recently bought a Beosystem 5500 and 2 Beovox S45-2 speakers, which I am really pleased with. I would however like to add more bass to the sound range. So my question is if I will accomplish that by adding a Beovox Cona to the system and is it at all possible to make it all work together?
I would really appreciate to have some input regarding this.
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Jan 29 2018 4:51 PM
No problem at all getting it to work - you’ll just need the proper cabling - but I doubt a Cona would add much to it in practice. It was designed to augment the CX50/CX100 which do not produce that much bass by themselves.
--mika
Nettan49
Posts 2
Nettan49 replied on Mon, Jan 29 2018 5:31 PM
Thanks for the input, so there will not be any approvement at all in your opinion to add the Cona? I will probably have to look at another solution regarding speakers.
Fritz
Posts 272
Fritz replied on Mon, Jan 29 2018 7:20 PM
Hi Nettan
The Beovox 45-2 is a three way Uniphase loudspeaker with three separate units tweeter, bass and a special phase link unit meaning three loudspeakers. You can check this by taking of the front.
BeoVox Cona was designed bo BeoVox C30-C40 and C75 and BeoVox Cona has a frequency range of 40-195 HZ. BeoVox S45-2 has a better performance.
Technical Data BeoVox  S 45-2 see below.
Brgds/Fritz
Technical Data Beovox  S 45-2
Continuous load 45 watts
Music load          75 watts
Impedance          4 - 8 ohms
Frequency range + 4 -8 dB    38 - 20.000 Hz
Distortion 250 - 1000 Hz      <1 % above 2000 Hz       <1 %
Sensitivity        5 watts
Brutto volume   25 Iltres
Dispersion        120°
Woofer              8"
Phase-Link unit     3 1/2"
Midrange unit
Tweeter   1"
Crossover frequencies   2000 Hz
Dim2nsions WxHxD    26 x 48 x 21 cm
Weight  7 kg
Page 1 of 1 (4 items) | RSS
