I have just bought a very nice system consisting of a Beomaster 5500, Beocord 5500 and a Beogram CD50 controlled by a Master Control panel 5500. Everything works great, apart from controlling the CD player with the panel. It works when you press play on the unit itself. Is this a compatability issue? Thanks Phil
Datalink problem.
-Missing pins in the DIN plug-Leads broken off inside the DIN plug-Bad protection diodes-Bad solder jointsAny combination of the above.
Thanks should this have a 7pin DIN cable?
bigphil: Thanks should this have a 7pin DIN cable?
Yes!
