Paging technician , bg 5500 transformer burnt
This post has 13 Replies | 0 Followers
godotz
Posts 26
godotz Posted: Sat, Jun 23 2018 5:55 PM
hi , my girlfriend accidentally plugged my 120 volt Beogram 5500 turntable to the 220v electricity outlet here in Hong Kong without using an 120v - 220v adapter .
she heard two pop sound and smelled some burnt plastic smell.
Is there a fuse inside the turntable?
What should I do now ? My heart is broken .
please help me .
regards
david
Saint Beogrowler
Saint Paul
Posts 780
Sad There is a fuse. Open it up and take a look to see if anything else has been cooked.
godotz
Posts 26
godotz replied on Sun, Jun 24 2018 6:49 AM
Thank you peter . Will do so when I get back home next week from the work trip .
In case it’s the transformer , do you know where can I buy this part to replace or which models of Beogram share the same transformer with bg 5500 ?
Regards
peter
Saint Beogrowler
Saint Paul
Posts 780
The parts in the BG5005, 5500, 3000, 3300, 3500, 4500, 6500, 7000, 8500, 9000 are largely interchangeable. People part these out on eBay, you can email Beoparts.com, I might have one in storage, there are Facebook trading groups for B&O. If you’re a gold or silver member here, you could post a wanted add.
You’ve got options if you are partly capable of repairs yourself.
You might even be able to convert it to a 220v transformer and save your lady some trouble and guilt in the future.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jun 24 2018 2:17 PM
Power supplies are not identical in RIAA and non-RIAA decks.
But how much has burned? Fuse, rectifier, transformer, something on the main board?
godotz
Posts 26
godotz replied on Mon, Jun 25 2018 8:32 AM
thank you peter , i will check it up right when i get back home .
thank you for your advise .
you surely know my situation because the most important thing is to calm her first .Big Smile
regards
david
godotz
Posts 26
godotz replied on Mon, Jun 25 2018 8:35 AM
hi martin ,
thank you for your info .
i am still on a work trip and do not know the damage in details .
as far as i remember , my beogram 5500 do not have riaa built in .
anyway , you guys are great !
thank you .
regards
david
godotz
Posts 26
godotz replied on Sun, Jul 1 2018 8:00 AM
Hi guys ,
opened up the beogram 5500 with no sign of life .
the fuse is not burnt and this cause me nervous .
i am not a professional technician but only have secondary school student  electronic techniques .
i have carefully  disconnected the power supply part and will start to check .first the transformer , then will try replace the voltage regulator. Wish me luck .
godotz
Posts 26
godotz replied on Mon, Jul 2 2018 6:44 AM
Hi Peter ,
After founding the fuse is without damage , i did check up the transformer , 120v input on the primary side but 0v output from the secondary winding .
Does it mean I need to find a new transformer ? Sorry for my ignorance . It is 30 years ago I put my fingers on a multimeter !
i found some replacement at eBay which are from Rx , 1800 or 5000 , outlook are identical but numbers printers on it are varied  . Mine is 8013274 , are they all the same ?
and some smaller pcb are 240veuro version ?
which one I should go for ? Please help and advise .
regards
david
godotz
Posts 26
godotz replied on Tue, Jul 3 2018 5:39 AM
Hi Martin.
Fuse is not burnt . transformer checked , 120v input but 0 volt out . Think I need to buy a replacement transformer at eBay . Will also change the voltage regulator ic too . Think these are the vulnerable parts of the power supply side , right ?
If I buy the 240v eu version transformer , the pcb seems different . Anything I need to concern ? Please advise .
regards
david
godotz
Posts 26
godotz replied on Tue, Jul 3 2018 5:41 AM
Sorry for the fat finger post .
Dillen
Posts 13,191
Dillen replied on Wed, Jul 4 2018 6:33 AM
godotz:
I cleaned it up a bit.
You have email.
godotz
Posts 26
godotz replied on Fri, Jul 6 2018 6:38 AM
Thank you Martin .
godotz
Posts 26
godotz replied on Sat, Jul 7 2018 5:06 PM
Hi , would you guys let me know the basic spec of the transformer of Beogram 5500 ?
output is how many Volt and how many A ?
And after the psb, the dc voltage is ?
just for reference. Thank you .
david
Page 1 of 1 (14 items) | RSS
