Beovox S80.2 and Beomaster 6500
This post has 6 Replies | 0 Followers
Tassos
Athens
Posts 323
Tassos Posted: Thu, Jul 19 2018 12:52 PM
Hello all,
I am a bit lost with all this RMS, IEC, etc ways of rating power output of speakers. I went through different sites, I read all the literature, I understood how measurements are made but I can not find an answer to a simple question.
Is it safe to power a pair of Beovox S80.2 by a Beomaster 6500?
Thank you for your answers!
Stereomensch
Posts 322
Hello Tessos,
don't think too much about it. It will work without any problems :)
regards Chris
Anders Jørgensen
Denmark
Posts 350
I have used S80.2 with Beomaster 6500 and it works great. They only reason for change was I also had S120 but the difference is hardly noticeable overall.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jul 19 2018 2:35 PM
Keep the volume at a level where there is no distortion and you'll be fine with practically any combination
of Beomaster and Beovox, you can think of.
Tassos
Athens
Posts 323
Tassos replied on Fri, Jul 20 2018 8:01 AM
Thank you all for you help!!!
Stereomensch
Posts 322
As far as I remember, the Beovox s80 were the recommended speakers for the beomaster 5000.
It should work without a problem :)
Here is the article about the beomaster 5000:
https://www.beoworld.org/prod_details.asp?pid=353
related products:
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Jul 20 2018 6:34 PM
If they sound dull, get new capacitors for the cross over. My dealer gave me a pair of these for nothing some years ago! Nice speakers!
Peter
Page 1 of 1 (7 items) | RSS
