Beolab 3 & AV Receiver
smkaps
Posts 3
smkaps Posted: Tue, Oct 2 2018 3:21 PM
Hello,
Just got a pair of Beolab3 speakers - should I have any issues connecting them to a Yamaha AV Receiver RX-V2700? My last receiver didn't have the appropriate capabilities. I have a turntable that I'm hoping to utilize.
Regards,
Simon
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Tue, Oct 2 2018 6:18 PM
If your receiver have variable line out, then you won't have any problems.
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Tue, Oct 2 2018 6:22 PM
On the web I just saw a picture of the back plate of your receiver.
You have some connectors called PRE OUT. You should use them to connect to your BL3 and be happy!
Howzit
Posts 94
Howzit replied on Wed, Oct 3 2018 8:22 AM
You can get RCA cables made with a standby/power trigger. This will plug I go to the 12v trigger plug.
Contact Steve for cables (you can see his ad at the bottom of the page).
I’m running Beolab 9s, Beolab 8000s, Beolab 3s, Beolab 2s all from a Yamaha.
As someone mentioned, they all connect through preouts.
Beolab 9 | Beolab 8000 | Beolab 6000 | Beolab 2 | Beolab 3 | Beosound 9000 | Beoplay A9 | Beomaster 8000 | Beovox M75, / S75, / S45.2
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi smkaps,
Yes, you can use Beolab 3 speakers with this receiver as it has variable RCA pre-out sockets fitted.  There is no need to use a voltage trigger with these speakers (although this is an option if you wish to force the speakers to stay on), as these these speakers have a Line mode to allow them to turn on automatically when the music plays.  You just need one of these cables for each pair of speakers to be connected to the receiver:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/105-126-av-processor-pre-amp-sonos-to-beolab-using-the-powerlink-din-sockets.html#/2-length-1m
Please set both speakers to "Line" via the small switch at the back.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (5 items) | RSS
