Beovision 10 with 6000 speakers won’t play beosound 9000
This post has 15 Replies | 1 Follower
Col
Posts 11
Col Posted: Mon, Dec 17 2018 7:24 PM
hi
in the same room I have a beosound 9000, Beovision 10-40 with 6000 speakers attached wired via Beolink cable.
both now switch on off with beo4 remote and tv works and turns on speakers.  But I can’t make beosound turn them on.   Cd spins up but speaker light remain at red.
Tried loads of combinations but I’m not sure which to change that would cause this
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Dec 17 2018 7:57 PM
Look for Masterlink Handbook to get very detailed information
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
BV10 i V.Opt 2 - BS9000 i A.Option 0....forudsat at der ikke er højtalere på 9000’eren.
Millemissen
Flensborg, Denmark
Posts 14,680
Oh, sorry - the added sentence means: assumed that there are no speakers connected to the 9000.
Col
Posts 11
Col replied on Mon, Dec 17 2018 10:58 PM
Correct
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Dec 18 2018 12:02 AM
BS9000, A-OPT 0
TV - V-OPT 2
Turn them both off at the mains, leave them for a few minutes - then power up the TV first, then the 9000.
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Dec 18 2018 5:53 AM
Col:
You are using a Masterlink cable, right? Do you know for sure it works?
Ralf
Col
Posts 11
Col replied on Tue, Dec 18 2018 8:19 AM
Ill give it a try as I’ve never turned them off just standby
Col
Posts 11
Col replied on Tue, Dec 18 2018 8:22 AM
Cable worked with last tv so I’ve ruled it out for now
question -  what sound settings do you use for video and audio? I can’t seem to get tv speaker and 6000 to both work together
Millemissen
Flensborg, Denmark
Posts 14,680
Default is: speaker 3 when sound from tv itself/video  -  two for what is coming from the BS 9000/audio ( = the external 6000’s alone).
Have a look in the settings/tv, if that should have been changed.
Have you tried manually (via the remote) to choose these - e,g. choose speaker 2, when the 9000 is playing.
Col
Posts 11
Col replied on Tue, Dec 18 2018 1:10 PM
Tried this to no effect bar remote no longer works on 9000. Tv seems fine
Col
Posts 11
Col replied on Tue, Dec 18 2018 1:19 PM
Thanks for that- as for selecting speakers I’ve never done that before and it just worked with old tv.  So I tried LIST >speaker>2 and nothing happens speakerlights stay red.  Tried 1 too for the hell of it !
Millemissen
Flensborg, Denmark
Posts 14,680
In the mentioned option settings - does the BS9000 start, when you press CD on the remote, when starting from standby?
Col
Posts 11
Col replied on Tue, Dec 18 2018 4:17 PM
Not since I tried the reset of a and v codes and reboot as per above - I did have that working before
Col
Posts 11
Col
Posts 11
Page 1 of 1 (16 items) | RSS
