hi,
hope everyone had a nice christmas holiday!.
whats the best way of connecting an apple tv to a BeoVision 7-40 mkII ( it has 3 scart sockets and the yellow, red. white phono/rca sockets as a 4th input ).
+ how should i program my beo4 ( it has the dtv/dvd/cd buttons ) to activate that input when i want to tune into the apple tv?
i have tried connecting the apple tv using a hdmi - rca lead to input 4, but i cant seem to tell the tv that i want to watch input 4! - iv read the manual over and over and cant for the life of me activate input4 and yes, i did configure input 4 in the tv menu as having extra equipment ( dvd2 ) plugged into it.
i then tried using an rca - scart connector and plugged this into av2 and programmed that into the menu and still nothing - so im not sure if the cable isnt wired up right ( is it even possible to convert hdmi to rca/scart ? ). or is my bv 7 mkII just too old to do this?
many thanks for any help that can be given!
If you are using a simple hdmi to SCART lead then the problem could be that hdmi is digital, whereas SCART is analogue.
Hence rather than just a 'lead' you need some sort of converter that will also do the Digital to Analogue conversion. Like this: https://smile.amazon.co.uk/Neoteck-Adapter-Composite-Converter-Supporting/dp/B01K7HYOAC/ref=sr_1_1_sspa?s=electronics&ie=UTF8&qid=1545824695&sr=1-1-spons&keywords=hdmi+to+rca&psc=1
I am not familiar with the BV7-Mk2, but if it has a DVI socket then there could be a better way of doing this. If so, let me know and I'll make a better recommendation.
