So you want to bridge your legacy ML over to your BV, right? So which BV is it and what are the other audio sources? Just need to understand what your scenario is and what we got to play within terms of devices.
Just to compare I got my own house wired up with ML-network and I have one BeoLink Converter NL/ML which bridges my BeoSound Moment over to the ML-network as it's a NL-unit. So in my case I only have one NL-device and the rest are based on ML-network.
For the light command handling I'm using the first version of the MasterLink Gateway which is ML-device and hocks in to the ML-network and handles light commands picked up by any device.
So, based on the above, a bit more information on what you have and whether it's ML or NL devices. As you have a NL/ML-converter you're your limited to what this can do and if you need a gateway to other system or control other devices, then yes you need the BeoLink Gateway unit to interact with. How are you today controlling your lights and what else is you want to handle?
kimhav:So you want to bridge your legacy ML over to your BV, right? So which BV is it and what are the other audio sources? Just need to understand what your scenario is and what we got to play within terms of devices.Just to compare I got my own house wired up with ML-network and I have one BeoLink Converter NL/ML which bridges my BeoSound Moment over to the ML-network as it's a NL-unit. So in my case I only have one NL-device and the rest are based on ML-network.For the light command handling I'm using the first version of the MasterLink Gateway which is ML-device and hocks in to the ML-network and handles light commands picked up by any device.So, based on the above, a bit more information on what you have and whether it's ML or NL devices. As you have a NL/ML-converter you're your limited to what this can do and if you need a gateway to other system or control other devices, then yes you need the BeoLink Gateway unit to interact with. How are you today controlling your lights and what else is you want to handle?
