Beocenter 7000 type 1803 belt needed
Jack
Rochester, NY, USA
Posts 41
Jack Posted: Fri, May 17 2019 9:12 PM
I have a Beocenter 7000 - I presume it is a type 1803 since I'm in the U.S. (There is no type label apparent either in or outside; radio is FM only so I assume it's not a type 1801.)
The question: where can I locate a replacement cassette belt? I can find belts for type 1801, 2 and 4, but no 1803. I'll guess they're all the same, but I want to be sure.
The amusing effect of heat within the BC7000: the old belt has deteriorated to the point that it melts when touched. Quite a mess trying to clean out the old belt. Wait a minute.....does the Beocenter 7000 have TWO BELTS inside it? There are pieces of a FLAT belt nearby. I don't see where a flat belt would be used. What are these pieces of a flat belt?
Thanks for your help.
JackM
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, May 17 2019 9:41 PM
I can supply correct belts, both for the tapedeck section and for the turntable.
New idler wheel rubber parts for the tapedeck too.
PM or email me.
Jack
Rochester, NY, USA
Posts 41
Jack replied on Fri, May 17 2019 9:50 PM
After posting the previous, I began to feel that it might sound pretty dumb to have access to a belt for types 1801, 1802 and 1804 and not catch on that they'd fit my type 1803. On the other hand, I don't want to spend fifteen bucks, wait eight or ten days with the unit opened up on my workbench, only to find out that B&O put a different cassette player in the US version for the same reason they didn't give us an AM/FM radio.
Another note - I cleaned up the smeared deteriorated belt with plain ol' alcohol and found an area of black paint removed! The bottom of the 7000's box now has a white stripe across the inside!. Nothing that'll show from the outside of the underside, but just plain alcohol did that?
JackM
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sat, May 18 2019 4:56 AM
Jack:
I just had a similar experience with a set of Penta pedestals, alcohol stripped the black paint clean off right down to steel!
Page 1 of 1 (4 items) | RSS
