Beolink Activ as audio master ?
This post has 4 Replies | 0 Followers
Silou
Switzerland
Posts 465
Silou Posted: Tue, Sep 3 2019 12:45 PM
is it possible using a Beolink Activ as audio master ?
Audio input on BL Activ with IR eye - ML cable to an another BL Activ / or a BL3500?
BeoLignage
Sweden
Posts 207
Hi Silou
unfortunately not, the audio input on the BL Active is the so called PC input and can only be selected locally.
see the manual page 7 on:
https://www.bang-olufsen.com/~/mediaV3/files/user-guides/BeoLinkActive/beolink-active_settingupguide_english.pdf
Silou
Switzerland
Posts 465
Silou replied on Wed, Sep 4 2019 5:17 PM
Thanks BeoLignage,
I missed; PC is locally only !!
What's about  BL Converter 1611 ? (An master seems to be necessary... )
My goal is to inject an external source into ML with the easiest/smallest "ML-managerdevice" .
BeoMatthew
Posts 46
Nope. A BeoSound product with ML would have to be present. Link kits cannot communicate with one another independently.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Sep 9 2019 1:17 PM
the Beolink Converter 1611 can be used as a Masterlink Master for a Masterlink Network.
The audio has to be 'pushed' in via the DIN connector A.AUXLink. The signal will be sent on the masterlink bus and can be used with various Beolink Slave devices (BeoLab2000, BeoLab3500).
The sound can be remote controlled with a B&O remote ( Vol+/-, Mute, Standby, Balance ...) to switch on the Mastelink Slave any audio command can be used like RADIO, CD,TAPE,...
This definately works fine.
Ralph-Marcus
Page 1 of 1 (5 items) | RSS
