Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Pat:Which colour is it, blue?
Michael: No it’s beige/brown. Here’s a video with how it sounds https://youtu.be/sLluRlqoEhU
I have one of the original A1's and love it, but it does suffer from distortion. I can play certain Spotify tracks and some cause it to distort. Never get that issue on the BeoSound 2 with the same audio track. Oddly I find the P1 suffers from less distortion, so often use that instead.
I have two early A1s. I have never heard it distort.
But i haven't played either of them for a year, so maybe i should try them again.
Hope it gets resolved very soon for your friend. It's frustrating. Especially if you actually recommended that device to them.
PaulGiles:Maybe the broken case fault? Take off the outside cover and look for cracks where the screws hold the black plastic parts.
mbolo01:To illustrate PaulGiles recommendation, this is how I fixed mine following advices found in this forum. I filled the screws holes with cotton (my choice) and put a tape on the holes, bass “farting” symptom disappeared and my A1 sounds like the first day: BS Moment, BS Core, BS Ouverture, BG 4002, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Hi there,
Is there something specific about "early" A1's? Is there such a thing like MK1 or MK2 etc?I only noticed they changed the package design at some point.
