Programmed BEO5/BEO6 remotes for years without any problem... until I get each time I started serialization the following message "Loading configuration failed - Please charge the Beo6 for 15 minutes, restart the Configuration Tool and try again !"
Well, it goes without saying that the battery level of the remote indicates full charge, but it doesn't help. Even if I charge the remote for hours, get the same message. It seems that the problem has nothing to do with battery level.
Did anyone encounter this problem, and knows how to solve it?
Thanks.
Have had this happen many times!
I try in this order;
1. Change USB socket you are using
2. Reinstall Beo5/6 USB driver
3. Try another computer
Let us know how you get on!
Struggling with exactely the same error and it's driving me nuts: Loading configuration failed - Please charge the Beo6 for 15 minutes, restart the Configuration Tool and try again !
Using XP Pro SP3 on two different pc's. CT 4.11.
Beo6 firmware version 2.11ahardware version 14supported version 0.23
Tried reinstalling, manually installing driver, everything I can think of, but do not succeed in solving this. Only thing I didn't try is hard resetting the Beo6 by keeping the center button pressed more than 30 seconds. It simply doesn't reset de Beo6 and I don't know of another way to reset it.
Kind regards,Joost
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Have you tried using another PC?
As an IT Infrastructure specialist I do not really believe in these kind of things solving themselves ;-)
I received a link to the newest version of the config tool from one of the members here, installed the new version and it works flawlessly from start. I guess it was a driver problem, or my Beo6 had already been upgraded previously to a firmware version that was to new to work correctly with config tool v4.11
Issue solved for me,Joost
Is version 6.0 the latest CT? Is there a newer version available?
