Beosound 4 glass door belt.
This post has 7 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Mon, Jan 27 2020 4:06 PM
I just got a BS4 for 60 euro, glass did not move, and was very loose, and all the rubber is starting to turn into goo, otherwise, everything works fine :)
Glassdoor is as simple as a broken belt, but B&O(at least in DK) will not sell me one as spare part, they will only take the complete unit in for repair, which in turn means a cost of 3-4 times the price I bought the unit for, for a single belt !!
Come on B&O, let us keep some of the old stuff alive by our selves !!
Oh well, the question is, does anyone know where to source a belt of the correct size ?
Thanks.
P.S I have removed the black goo on the front panel, and cd-bay with nail-polish, and after some plastic primer, and mat black spray paint, it looks a million again :) Now just need to do it on the body also...
/Weebyx
fkatze
Posts 92
fkatze replied on Tue, Jan 28 2020 1:38 PM
I've been looking for a belt for my BC900 - and stumbled across turntableneedles.com  Can't say if they are any good but they seem to have a lot of stuff.
Dennis
Denmark
Posts 627
Dennis replied on Wed, Jan 29 2020 10:51 PM
Did you try to buy it directly from B&O or through a dealer? I recently bought a locking mechanism for a BeoPlay V1 through the dealer in Esbjerg without any problems so maybe they're worth a try?
/Dennis
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Jan 30 2020 8:14 AM
Dennis:
/Dennis
I tried my dealer, they could not buy it, or so they say.
I will try the Esbjerg dealer :)
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Jan 30 2020 10:09 AM
Dennis:
/Dennis
Belt found ;)
/Weebyx
Dennis
Denmark
Posts 627
Dennis replied on Thu, Jan 30 2020 8:39 PM
Good to hear that you found a belt Wink
/Dennis
huskvarn
Posts 13
huskvarn replied on Thu, Feb 11 2021 12:34 PM
Same problem, were did you find the belt ? =)
Thanks!!
huskvarn
Posts 13
huskvarn replied on Wed, Feb 17 2021 8:05 AM
Answer to myself and those wich may need this information :
It is a 1,7mm radius belt, diameter 50mm (mesured 102mm lineary on the brocken one). Originaly it is round, but I've fit a square one and it works like a charm. Have bought on Amazon a batch of belt and you will find the good one in it !
Cheers
Page 1 of 1 (8 items) | RSS
