Martin:I have now downloaded and installed sw 3.0.0.527. According to my dealer this is an officiel release and not a Beta sw.
That's curious, as I emailed B&O Support and they told me exactly the opposite:
"Thank you for reaching out to Bang & Olufsen Support regarding your BeoLab 90 and Beolab 50.
We are glad to assist you to update your products to the latest software but after checking our system, it seems that your products are already updated to the latest software.1 - Beolab 90: V2.3.4.7045 which is the latest market release.2 - Beolab 50: V2.3.4.7045 which is also the latest market release."
politician:That's curious, as I emailed B&O Support and they told me exactly the opposite: " Thank you for reaching out to Bang & Olufsen Support regarding your BeoLab 90 and Beolab 50. We are glad to assist you to update your products to the latest software but after checking our system, it seems that your products are already updated to the latest software. 1 - Beolab 90: V2.3.4.7045 which is the latest market release. 2 - Beolab 50: V2.3.4.7045 which is also the latest market release."
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
politician:That's curious, as I emailed B&O Support and they told me exactly the opposite:" Thank you for reaching out to Bang & Olufsen Support regarding your BeoLab 90 and Beolab 50. We are glad to assist you to update your products to the latest software but after checking our system, it seems that your products are already updated to the latest software. 1 - Beolab 90: V2.3.4.7045 which is the latest market release. 2 - Beolab 50: V2.3.4.7045 which is also the latest market release."
Hi Raslaw,
When You have had time to check your new update (527), can you see if you experience any differences vs your "old" software (257).
Best RegardsMartin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Martin:Hi Raslaw, When You have had time to check your new update (527), can you see if you experience any differences vs your "old" software (257). Best Regards Martin Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K.
I emailed Support back at B&O, asking whether v3.0.x is beta software and got the following rather vague response:
"Thank you for your reply.
It could potentially be a beta firmware yes. The reasons for them having access to it could be varied from beta testing to needing a fix the firmware in question provides and accepting the potential bugs."
Wonder whether @Geoff Martin could throw any light on the situation?
politician:I emailed Support back at B&O, asking whether v3.0.x is beta software and got the following rather vague response: " Thank you for your reply. It could potentially be a beta firmware yes. The reasons for them having access to it could be varied from beta testing to needing a fix the firmware in question provides and accepting the potential bugs." Wonder whether @Geoff Martin could throw any light on the situation?
Martin:Hi Raslaw, When You have had time to check your new update (527), can you see if you experience any differences vs your "old" software (257). Best Regards MartinBeovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K.
Michael: politician: I emailed Support back at B&O, asking whether v3.0.x is beta software and got the following rather vague response: " Thank you for your reply. It could potentially be a beta firmware yes. The reasons for them having access to it could be varied from beta testing to needing a fix the firmware in question provides and accepting the potential bugs." Wonder whether @Geoff Martin could throw any light on the situation? Thanks for that. It’s a bit humorous but it is also the company I have gotten to know through the years. We shall not forget it is a small company doing very exquisite technology. And they are danish :).
With a Swedish CEO ;)
I got the information below from my dealer regarding 3.0.0.527:
It says "no new features" below, BUT there is ONE new feature. You can switch OFF Beolab 50 with the B&O-app with this new software and still have the television ON.
Version 3.0.0.0527 Release date 19th October 2020 Released for Nordics: 19th October 2020 Released for rest of world: 26th October 2020 New features: - None Symptom: - Speakers are losing connection to each other AR19212 - Distance, Level, and Role not working AR19870 - Autocalibrate does not work AR19835
I think the big "new" thing is that the BL50 with this new software is always connected to ethernet even when they are in "deep standby". Before we have to "wake up" the speakers but now they are awake with Ethernet all the time.
I will in this weekend try to listen more to music and see IF I can hear a better sound quality than before. I have not had so much time since I did the upgrade to listen at music and compare the sound quality with the old softwarel.
Best Regards
Martin:Hi Raslaw, I think the big "new" thing is that the BL50 with this new software is always connected to ethernet even when they are in "deep standby". Before we have to "wake up" the speakers but now they are awake with Ethernet all the time. I will in this weekend try to listen more to music and see IF I can hear a better sound quality than before. I have not had so much time since I did the upgrade to listen at music and compare the sound quality with the old softwarel. Best Regards Martin Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K.
Sorry michael. You don't control this thread.
Updated and...... disaster!
Where do we go from here? I actually don't know.
All day at the dealer with suggestions but no results.
Did I really buy into 1/2 my retired life trying to get a pair of speakers to do as they said on the tin?
They are now unplugged. I cannot listen to them, My A2 sounds better!
What is known as a Clusterf@@k!
But at least it ownly cost 26,000 pounds!!!!!!!!!!!!!
I've got my 50s arriving for installation in a few weeks.
Certainly hoping that I dont have to report back with any similar or major issues.
Beofile7: Sorry michael. You don't control this thread. Updated and...... disaster! Where do we go from here? I actually don't know. All day at the dealer with suggestions but no results. Did I really buy into 1/2 my retired life trying to get a pair of speakers to do as they said on the tin? They are now unplugged. I cannot listen to them, My A2 sounds better! What is known as a Clusterf@@k! But at least it ownly cost 26,000 pounds!!!!!!!!!!!!!
Sandyb:I've got my 50s arriving for installation in a few weeks. Certainly hoping that I dont have to report back with any similar or major issues.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I'll drop you a line, Mikipidia. Thank you!
Beofile7:Sorry michael. You don't control this thread. Updated and...... disaster! Where do we go from here? I actually don't know. All day at the dealer with suggestions but no results. Did I really buy into 1/2 my retired life trying to get a pair of speakers to do as they said on the tin? They are now unplugged. I cannot listen to them, My A2 sounds better! What is known as a Clusterf@@k! But at least it ownly cost 26,000 pounds!!!!!!!!!!!!!
Martin:Hi Michael, I also got the software 3.0.0.527 and have also tried other variations of the 3.0 software. My feeling is that the BASS is much less with this new software tnan the old 2.3.4.7045. What is your opinion about the Bass response? I dont feel that the sound quality is improving. I have rolled back to 2.3.4.7045 Best regards Martin Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Hi Esax,
Have You experienced the same as me with much lower BASS-response with the new software 3.0.0.0527?
Have experienced other problems than the "BASS" problem?
Martin:Hi Esax, Have You experienced the same as me with much lower BASS-response with the new software 3.0.0.0527? Have experienced other problems than the "BASS" problem?Best Regards MartinBeovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K.
Mikipidia:Have any of you retuned them with the mic?I lost my setting pre sw upgrade, then upgraded sw and then re tuned them and they sound bloody fantastic. Even more so than before and the punch is still there, so maybe it’s the “old” tuning file with the new sw that makes it sound extra different? Just a thought. New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0Mikipedia on YouTube (finally )https://www.youtube.com/c/MikipediaOld: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Directly after the sw update to 3.0.0.0527 I also noticed at least the same sound quality as with the old software. I have read somewhere that you should factoryreset the speakers after every sw update and I did that. This was an mistake.
After the factory reset all the bass respons was gone. I have tried to fiddle arround in the Bl 50 webUI and changed latency mode from Auto to Low. And with this change the nice sound quality with good bass come back again.It shoud be the opposite, low should sound worse than high latency.
B&O have done something very wrong with the new software especially with the latency setup. If I change from Low to High all bass dissapear.
With the old sw I always had Auto or High latency when listening to music. Now I have it on Low and the sound is pretty good. Very strange.
So DONT make factory reset on the speakers with this new sw because then the Bass response will dissapear in Wide beam on high/auto latency when listening to music.
Best regards
I order to get the Bass response back you can also have the speakers in Wide beam and change the latency from Auto/high to Low when listening to music. I found out that this latency change will give you back the nice total sound quality with very good bass response in wide beam.
Mikipedia is right about that only wide beam is affected but until a sw correction is coming just change the latency to low and everything works as it should when listening to a music source.
Hi Mikipedia,
I have a special preset for just music in 2.0 setup. It is this preset that I have changed latency from high to low. Then I have other preset for 5.0 setup and this preset is still at auto latency just to get syncronization between all 5 channels. The interesting thing is that when I look at something on tv and using "auto" on the latecy and wide beam then all bass is there. It is just when using audiomode on the Tv and auto/high latency combined with wide beam where the bass has dissapeared.
/Martin
