BeoLab 5000 Plastic Panel Cover
This post has 5 Replies | 0 Followers
jkhamler
Posts 286
jkhamler Posted: Wed, Mar 14 2012 2:43 PM
I'm missing the small plastic front panel from a Beolab 5000 (where the display is).
Does anybody have any smart ideas on where I can find a spare?
Regards, Jonathan
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Thu, Mar 15 2012 11:37 PM
Maybe I can help Jonathan but you have to wait. My just aquired Beolab 3000 flatpanels has funny enough green displays and according my information this is used on a Beolab 4500. The plastic cover (display window) dos not entirely shows all characters, it's a little bit to small.
I'm trying to let these covers made which I btw already did for a Beogram 6000Smile with excellent results.
Brengen & Ophalen
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Leslie,
Sounds as if you have 4500 amps attached to your Vox 3000's.   The plastic cover is held on with double-sided tape which, as always, disintegrates.  As a result your plastic covers might not be centered properly.  Here's what my display looks like:
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Mar 16 2012 4:23 PM
MediaBobNY:
Leslie,
No Bob, really, the label at the backside of the amp unit shows definetely Beolab 3000 and I had a new pair once of 4500 perspex covers from which the display window (in greenm) was a bit wider then the 3000/5000 amps. But still it has a green display. WeirdConfused Some tech guy must have replaced the display from orange to green....
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Mar 20 2012 4:57 PM
2 pair of new panel cover to be produced by my local supplier. Finished in 2-3 weeks.
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Apr 20 2012 10:39 PM
See the results of my covers on this thread! It's still a green display on a Beolab 3000Whistle
Brengen & Ophalen
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
