I have taken up the idea of adding a Core into my setup.
Currently I have BS1 integrated to my BV11 (with BL3s and BL11 connected) so I can access BS1 sources e.g RADIO and MUSIC from my BR1 (IR).
I now thinking of removing BS1 from this setup and integrating a Core in exactly the same way, and also connect my Beogram/RIAA to the Core.
Questions:
- Will I be able to assign the Core sources to the BR1 as I have done now? I assume so...
- I read somewhere that you can adjust the gain on Core line input. Correct?
- Heard somewhere it lack Chromecast but webpage says it has Chromecast. Correct?
- I do not intent to change the remote so I will use the app if I want to e.g play a record. Any drawbacks with using the app in such case?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
You can do pretty much the same as of now - with the addition of the line-in possibility, that the Core offers.
However, you could (physically) connect the turntable directly to the BV11 - using the analog input port there....of course with the right adapter cable.
Built-in to the BV11 is also a netradio function - don’t you use that?
(Yes, the Core has support for Chromecast built-in).
Millemissen:You can do pretty much the same as of now - with the addition of the line-in possibility, that the Core offers. However, you could (physically) connect the turntable directly to the BV11 - using the analog input port there....of course with the right adapter cable. Built-in to the BV11 is also a netradio function - don’t you use that? (Yes, the Core has support for Chromecast built-in). MM There is a tv - and there is a BV.
Hiort:but I’m after the possibility to adjust the gain on Core input
I’m in the same situation. It annoys me that I can’t stream music directly to my bv11/bl5/bl3 living room setup. How would you connect the Core to the bv11 Hjort in order to say airplay or use the app to stream music?
Currently I have to utilise the Core that runs my dining room bl8000/bl11, then turn on the bv11 and then add the bv11 on the app to the Core as a link speaker. It does work but it means the dining room is playing all the time as well..
Brian:I’m in the same situation. It annoys me that I can’t stream music directly to my bv11/bl5/bl3 living room setup. How would you connect the Core to the bv11 Hjort in order to say airplay or use the app to stream music? Currently I have to utilise the Core that runs my dining room bl8000/bl11, then turn on the bv11 and then add the bv11 on the app to the Core as a link speaker. It does work but it means the dining room is playing all the time as well..
This pdf from B&O should tell you what you can and what you can not.
https://www.google.dk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjn-uP6zI_tAhXD2-AKHYPaAQ0QFjAAegQIBRAC&url=https%3A%2F%2Fbogo.custhelp.com%2Fci%2Ffattach%2Fget%2F1304261%2F0%2Ffilename%2FMultiroom%2B-%2Boctober%2B2017%2B-%2BPDF%2Bhandout.pdf&usg=AOvVaw2djMCyPD2aLhEGoe3lmdoB
PaulGiles:Yes, core integration to BV11 works. It “disappears “ from the APP but you see it in BeoTool and it shows connected to BV11. You can stream etc as normal then to the BV11 via the core but it is just named as the Beovision room name.
Super. Thanks.
