I'm considering buying a BV 10-40 and new to owning any B&O TV. Should I be buying, what is effectively a 10 year old TV and is there anything I should look out for?
Cheers
Hi Musicaltinkerer,
Beovision 10 is a beautiful piece of art but when you look at the product and sound quality I'm not impressed.
Beovision 11-40 is more expensive but is worth every extra penny in my opinion. Have a look at this thread which sums it up pretty well: (although the discussion is for the 46 inch a lot of the points are the same for 40)
https://archivedforum2.beoworld.org/forums/t/12706.aspx
Regards,
Soren
I bought my BV 10-40 about 7 years ago and it is going strong and is superb. Great sound and picture, and I am really happy with it. I have it on the wall and in my humble view it looks beautiful!
Good luck and happy viewing, whatever you buy.
musicaltinkerer: I'm considering buying a BV 10-40 and new to owning any B&O TV. Should I be buying, what is effectively a 10 year old TV and is there anything I should look out for?
I owned a BV10-40 which feels like an eternity. I'm not convinced I'd recommend such an old TV. Why not look at the BV11-40 instead?
I moved up from a BV10-40 to 11-40 (later a 11-46) and never looked back. Apart from the BV10-40 orange fret which was stunning and they discontinued, the BV11-40 felt like an upgrade in many ways.
Soren, many thanks.
Clearly good advice, after reading from the link, there are more differences than I was aware of. Will definitely look at the 11. Very exciting prospect!
James
Thank, definitely makes sense to go for the 11, cheers for the advice.
moxxey:I owned a BV10-40 which feels like an eternity. I'm not convinced I'd recommend such an old TV. Why not look at the BV11-40 instead? I moved up from a BV10-40 to 11-40 (later a 11-46) and never looked back. Apart from the BV10-40 orange fret which was stunning and they discontinued, the BV11-40 felt like an upgrade in many ways.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
