Hi All,
I have not been able to find the answer to this question so I hope someone here can help.
I have a Beogram 5000 and a Beocenter 9000 - with remote and using data link.
I was thinking of adding a phono pre-amp but I'm unsure how that would work. I don't want to lose the data link option (remote control) and I guess if you add a phono pre-amp you will no longer use the phono input on the Beocenter 9000.
Anyone done this before?
Thank you,
/jakob
Yes - I don't think it sounds very good.
