Bridging Tidal and Beolab 20
This post has 6 Replies | 0 Followers
Jayson234
Posts 11
Jayson234 Posted: Sat, Feb 27 2021 6:32 AM
Hi All,
Apologies if this is a bit of a dumb question, but I was hoping to get some advice around our current setup.
At the moment, we stream music mainly from Tidal through the below:
Tidal (from iphone or ipad) --> Apple TV --> Klipsch HD Control Centre --> Beolab 20s.
I was hoping to ask if we might get any improvement in sound if we went Tidal --> [something else] --> Beolab 20s?
Thanks a lot in advance!
T
Curly
FL, USA
Posts 366
Curly replied on Sat, Feb 27 2021 7:00 PM
With “something else”, it may sound different but whether it sounds BETTER is up to your ears only, my friend.
Do note, however, that BL20 can only accept a maximum of 24/96, so it cannot play full TIDAL Master MQA of 24/196. Because you’re unlikely to get any higher rez streaming by using “something else”, I think if you feel the sound is better will just be a question of subjective taste.
I couldn’t hear a difference with some A/B testing using TIDAL on my BL17, FWIW...
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
Curly
FL, USA
Posts 366
Curly replied on Sat, Feb 27 2021 7:02 PM
Here’s a relevant thread.
https://archivedforum2.beoworld.org/forums/t/42885.aspx
Jayson234
Posts 11
Jayson234 replied on Sun, Feb 28 2021 11:35 PM
Thanks so much Curly, really appreciate it!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Mar 1 2021 9:35 AM
Skip the ATV in your setup and use a Mac or PC to run Audirvana on it.
Audirvana remote (also for Tidal/Qobuz on your iPad) - Mac/PC - Klipsch - BL20
Also possible:
A much under appreciated and unknown source type available in most B&o NL devices to consider : "Music Stream".
With Audirvana Tidal/Qobuz can be upnp/dlna streamed directly to B&o
Jayson234
Posts 11
Jayson234 replied on Mon, Mar 1 2021 11:21 PM
Thanks Carlopa, apologies for the ignorance, but would this be different from getting a Bluesound Node 2i?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Mar 2 2021 4:54 AM
Jayson234:
no, but presenting alternatives, which may sound better.
and easier to test, presuming you already have a MAC/PC and use the 30 days test period of Audirvana
Page 1 of 1 (7 items) | RSS
