Hi All,
I recently bought the Beosound Stage/Beoremote/LG Tv bundle - our first B&O purchase. I don’t have the tv installed yet but am using the stage and remote as a music speaker.
I noticed on a YouTube video that the Manchester B&O guys put out that he was able to store radio stations on the Beoremote - with each station listed on the remote’s screen as he scrolled through them.
I’ve registered with tune-in and am able to choose radio stations through the B&O app but I’m not able to see any option for storing radio stations into a list on the remote that I can scroll through. Would anyone be able to advise if this is possible and if so how to please?
Many thanks,
Des.
The list you access on the Beoremote One corresponds with your list of TuneIn favourites. You can favourite stations in the B&O app or in the TuneIn app. There might be some delay before they are synchronised.
Once you have stored some favourites you can also use the number keys on the Beoremote One to select a channel, provided that your selected source is already TuneIn.
Finally, you can also program a specific channel under one of the MyButtons by long pressing the desired MyButton when the preferred channel is playing.
