BL 28 - Excellent 'Tech Info' Guide
This post has 9 Replies | 2 Followers
BeoFrederic
Posts 276
BeoFrederic Posted: Thu, Jul 8 2021 12:24 AM
FYI.  This is a quick recommendation for the BL 28 Technical Information Guide.  Almost certainly written by Geoff Martin, it is at pains to make available to the layman (me) such topics as beam width control, ARC, ABL, room acoustics and speaker placement.  Much of the discussion is applicable beyond the BL 28.
Geoff Martin
Struer, Denmark
Posts 672
thanks. ;-)
-g
BeoJosh
Posts 89
BeoJosh replied on Thu, Jul 8 2021 7:58 PM
Thanks. This will come in handy, as my 28s are being installed in my office next week (along with a pair of 50s in my family room). Very excited!
Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB Stand
Beolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Level x2, Beosound Core x2, Beoplay M3, Beosound 9000, Beogram TX2, Beogram 6500 White Edition, 4000c (on order), Beoremote One x8, Beoremote Halo x3, BLC NL/ML
Beoplay H95 x3, Beoplay EQ x2, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
Geoff Martin
Struer, Denmark
Posts 672
If you actually manage to stay awake while reading the TGS, and you find any typos or errors, please let me know and I'll clean it up on the next version.
Cheers
-geoff
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Thanks Geoff,
That is a really useful and informative guide, the notes on speaker placement should be particularly helpful to potential owners.  I didn't see any mention of the "Beosonic" control wheel in the app for making sound adjustments.  I think this could be useful to cover, particularly as the treble adjustment in Beosonic appears to act from a lower frequency than the treble control in the Equaliser?
Kind regards, Steve.
Steve.
www.soundsheavenly.com
wanc1
Posts 29
wanc1 replied on Fri, Jul 9 2021 2:29 PM
Hey geoff,
I was wondering why the volume for the 28 goes from 0-100 instead of 0-90 on the 50s and 90s. Can you please illuminate us on this difference?
-Ray
Silou
Switzerland
Posts 465
Silou replied on Sat, Jul 10 2021 12:17 AM
Thanks Geoff,
Do you have a similar guide for BL 5 ??
Thanks !
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jul 10 2021 11:34 AM
Thank you Geoff!Big Smile
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Allianz
Posts 27
Allianz replied on Sun, Jul 11 2021 11:25 AM
I would love if this 28's Technical Information Guide could be updated to cover also technical parts like amps, dacs etc just like 50's and 90's guides. So wont be reason to take apart new speakers to see what they have been eating. Stick out tongue
I am also curious about that 0-100 volume range.
Beolab 50, Beolab 28, Beolab 19, Beolab 17, Beolab 12-2, Beolab 12-1, Beolab 11, Beolab 7-4, Beolab 3, Beolab 2, Beovox 2-2, Beocenter 2
Beosound 9000, Beosound 4, Beosound 35, Beosound 2, Beosound 1, Beosound Stage, Beosound Level, Beosound Core, Beosound Essence mk2
Beoplay A9 mk3, Beoplay S8, Beoplay A1, Beoplay P2, Beoplay H95, Beoplay H9i, Beoplay H4
Geoff Martin
Struer, Denmark
Posts 672
Hi again,
Note that BeoSonic does not have an effect when you're using the Beolab 28s in Power Link mode.
The volume range of all B&O Products has always been decided by the UI/UX designers over the years, and, as those of you with older B&O Products can attest, has changed many times. Some examples: 0.0 - 6.0,  0 - 72, 0 - 90, and 0 - 100. The newer products have the 0 - 100 range, however, in order to maintain compatibility with older devices, the "old" 0 - 90 steps have exactly the same gains as the "new" 0 - 90. You just get 10 extra steps on top.
Some people who confuse listening level with volume setting may ask "Why do you need 10 more steps? Isn't it loud enough already?" However, it's important to remember that the output level is a result of the combination of the volume setting and the level of the signal. A quiet moment in a movie at volume step 70 might be nearly inaudible, whereas a Slipknot tune on the same device, still at volume step 70 might be painfully loud.
This is why, generally, people who listen to "loud" (aka pop and rock) music often ask me why the smaller B&O loudspeakers start having to protect themselves at volume settings that are lower-than-maximum. The reason is that some people (like me, for example) also listen to music that gets quiet sometimes - and then it should be possible to turn this up enough.
I wrote a blog posting related to this topic, if it's of interest:
https://www.tonmeister.ca/wordpress/2021/05/07/turn-it-down-half-way/
There is no "Technical Sound Guide" for the Beolab 5 - however, the "normal" user guide has some technical information in it.It can be downloaded from here
https://support.bang-olufsen.com/hc/en-us/articles/360041570952
cheers
-geoff
Page 1 of 1 (10 items) | RSS
DigiCert Secured Site Seal
