Any suggestion as speakers for a small room
This post has 10 Replies | 1 Follower
caiusbonus
Posts 7
caiusbonus Posted: Thu, Jul 8 2021 10:55 AM
Hi, I have a beocenter 5000 and a non Beo TV In a small room (around 9 square meter). Now I am planning to add some speakers to connect the BC5000 and the tv as well. Any recommendations? The space is quite limited and maybe panel or otherwise small speakers preferred. I had thought maybe Beolab 4000 or some smaller from RL series..
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jul 8 2021 12:37 PM
Beocenter 5000 was made for passive speakers. It won't connect to active speakers without some "adapting".
I would suggest Beovox S45 or S45-2 (type 63xx) or perhaps Beovox 3000/5000 panel speakers.
cooldude
Posts 101
I always found that CX100  speakers are especially well suited to small rooms.
cooldude
Posts 101
lawrencejmcook
Posts 742
cooldude:
I love the look of the CX100s and have a couple of pairs myself, but in my opinion they have searing treble and need careful positioning.
Lawrence
cooldude
Posts 101
lawrencejmcook:
Lawrence
Maybe time to recap them. Made a difference on mine.
lawrencejmcook
Posts 742
cooldude:
I don’t doubt that mine need recapping, but the new ones I auditioned at B&O Coulsdon (yes, a long time ago) sounded shrill. I was horrified, but ended up collecting a couple pairs in different finishes purely for the looks.
They sound ok off-axis, and with a Cona or two (one per channel).
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Jul 9 2021 5:34 PM
Have CX100s attached to my 5500 system - never shrill - I wonder if they were set up in dealer fashion to sound exciting! However I would echo the S45.2 thought above - fantastic smallish speaker.
Peter
cooldude
Posts 101
Peter:
The S45.2 are indeed great classics, but definitely bulky compared with the CX's. My office is about the same size as the OP (9 sqm) and I sure would not be able to fit them in here.
caiusbonus
Posts 7
Thank you for your kind replies. Regrettably BV45-2 are too big for this purpose. I have thought maybe I could install some smaller speakers from Bv C(x) series quite close each other (as sort of soundbar-like) as I want to use the speakers with the tv as well and as the space is quite tricky, I most likely must install speakers under the tv side by side. There's no room for a speaker on the right Side of the tv (corner and door).
Svenni
Berlin, Germany
Posts 48
Svenni replied on Wed, Jul 14 2021 9:30 PM
Since they need to be under the TV I'd look at Beovox RLs (using the built in stand).
Beoplay A2
Beoplay Earset
Beoplay H6 (Gen 2)
Beoplay S3 (pair)
Beoplay S8
Beovox CX50 (2 pairs)
Beovox RL 6000
Page 1 of 1 (11 items) | RSS
