Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:And in Beosound 1 as well. I tried to change the delay and it appear you need to do that on each device individually.
Hiort:Same setting available in M3s. I generally have real problems with Airplay over multiroom since speakers do not sync.
mbolo01: Do you mean you have sync issue when streaming AirPlay 2 to multiple B&O speakers or do you have sync issue when distributing AirPlay over B&O multiroom?
The sync issue is when I use Airplay 2 only. If I airplay to one unit and use multiroom to the others it works perfect.
mbolo01:Do you mean you have sync issue when streaming AirPlay 2 to multiple B&O speakers or do you have sync issue when distributing AirPlay over B&O multiroom? I use the latest every day for many hours and I never noticed any sync issues. BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
Hiort:The sync issue is when I use Airplay 2 only. If I airplay to one unit and use multiroom to the others it works perfect. Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Homeoffice: M3, Beocom 2 Library : Beosound Emerge, Beocom 6000 Bedroom : M5, Essence remote Travel : Beoplay E8 2.0, Beoplay P2, Beoplay Earset
leosgonewild:2.4 vs 5 ghz makes big difference for me. 5 ghz network has major sync issues. 2.4 ghz works like a charm. "You think we can slap some oak on this thing?"
Dyssegaard: Have you been able to fix the problem using this new latency setting?
No, I have not tried yet :)
Dyssegaard:Today I have discovered that my BV11 can no longer join a Spotify stream via Spotify Connect to one of my M5s.
That made me curious!
So I had to try here.
Just like before I can easily play via Spotify Connect to my Essence MK2 and join in from my BV Avant 1.gen……which should basicly be the same.
I haven’t noticed any changes there.
Millemissen:That made me curious! So I had to try here. Just like before I can easily play via Spotify Connect to my Essence MK2 and join in from my BV Avant 1.gen……which should basicly be the same. I haven’t noticed any changes there. There is a tv - and there is a BV.
Millemissen:That made me curious!So I had to try here.Just like before I can easily play via Spotify Connect to my Essence MK2 and join in from my BV Avant 1.gen……which should basicly be the same.I haven’t noticed any changes there.There is a tv - and there is a BV.
