Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Dmacri,
I have also the beovirus and I entered into the b&o video world recently.
I own a beovision 5 plasma (non hd) and a beovision 7.40 hd ready.
For daily use, I do prefer my BV 5 (non hd content).
The problem with LCD HD ready or full HD is that they absolutely need HD content in order to display a very good picture.
I have a big collection of dvd and tv programs in my area are still in SD definition (only some program in HD).
The plasma is smoother than a LCD.
The sound on the BV5 is really good.
Unfortunately, the BV5 is heavy and hard to find, because nobody wants to send it.
When you add tv set to your beolink system, you are then able to use new function like sending the sound from a beosound to a beovision or control your beosound from your tv set in another room.
Even if the beolink system is now old, it is a usefull part of the B&O world.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
So, a bv 7 should be fine.
If it is possible try it with your own blu ray because some bv 7 are suffering of dark image.
For example, mine (a bv7.40 mk2) has this little issue.I have to pay for a software update (8.14) in order to solve this problem.
It seems that the image is too dark when using blu ray games on a ps3.
If you have the chance to buy a beolab 7.1 or 7.2 with it for a reasonable price, take it. its sound is amazing.
I use a beolab 7.2 as front speaker/center speaker with my yamaha receiver.
I put the beolab 7.2 on the ground.
The bass are really powerfull.
i tried with beolab 3 / beolab 6000 and I do prefer the beolab 7.2 alone.
I use the yamaha dial lift function in order to lift the sound up to the screen.Very efficient.
Good luck for your search.
Unfortunately a beomaster 5000 doesn't have powerlink built in.
So, I think it will be impossible.
dmacri:Ok, how about opinions - a new V1 32" or a used BV 7-32"? And if the B7, which version?
The V1 32" - for sure!
Greetings MM
Millemissen:The V1 32" - for sure! Greetings MM
Well, happy honeymoon then - with that little sweetie
Double wishes, sorry.
Start eating your spinach to day Popeye !
Have you any idea how heavy they are ?
An outstanding TV.
Congratulations!
Your Beo4 most likely needs a new display. Do NOT pay the extortionist prices they sometime go for on fleaBay, ask your dealer first. It's an easy job for a handy person, and some dealers might even replace it while you wait if they don't have anything better to do.
--mika
olvisab: For example, mine (a bv7.40 mk2) has this little issue.I have to pay for a software update (8.14) in order to solve this problem.
Any idea what this update fixes, I don't have it on mine?
Thanks, Beoaus
tournedos:Congratulations! Your Beo4 most likely needs a new display. Do NOT pay the extortionist prices they sometime go for on fleaBay, ask your dealer first. It's an easy job for a handy person, and some dealers might even replace it while you wait if they don't have anything better to do. --mika
