Are you 100% confident they can be sereo paired?The bigger M5 can't...
leosgonewild:A local store was selling out their supply. 100€ per speaker. I have 10 now
leosgonewild:Yes, then can be stereo paired through the Google Home app. It is possible with M5 also.
a. Is the left signal send to the speaker set Left and the right signal send to the Right speaker by an app casting?
b. Or is the original signal cast to both speakers and the speaker due to its setup reproduce the correct signal?
c. Or is this a misinterpretation and both signals left and right are the same?
b. would be interesting! then one would expect NL could do the same!
