Can Beocenter 8000, RL 6000 Speaker and BeoVision 7 40inch MK2 720p HD/LCD TV work together without Beolink ML/MCL Passive Amplifier?
Sure, just use a BeoLink-Converter (http://www.beoworld.org/prod_details.asp?pid=983) - ML from tv and A-AUX from the BC8000.
It is a classical setup.
To get the sound from the tv to the BC you have topress AV before 'source'.
But - really - I would buy a used ML/MCL Converter/2P for driving the passive speakers direct from the tv.
It is easier to control and gives you center and front channels when watching (listening to) tv.
N.B. You would need the BeoLink Converter anyway - to get the sound from the BC to the front speakers of the tv!
By the way, welcome to BeoWorld
Greetings Millemissen
Thank you.
