Anyone knows what this plug is meant for on my BM6500
This post has 27 Replies | 1 Follower
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie Posted: Fri, Sep 20 2013 8:50 PM
Click on it to see the whole picture....I'm talking about the flying lead on the right side of the BM6500
Brengen & Ophalen
olvisab
Posts 1,391
olvisab replied on Fri, Sep 20 2013 9:28 PM
Hi Leslie,
Well, maybe this will be my only chance to learn something to the biggest collector of b&o in the world :)
Is it a direct connection for a beomic, like a bm5 or 6 ?
BR
olivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Sep 20 2013 9:41 PM
I don't know Olivier, it looks original, no hanky panky inside...
Brengen & Ophalen
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Sep 20 2013 9:44 PM
Connection for an external IR transceiver.
--mika
Millemissen
Flensborg, Denmark
Posts 14,680
I read 'Line In/Out'.
Is there a physical connection behind?
Anders Jørgensen
Denmark
Posts 350
Good question.
I have 3 BM6500 so far they all had one and I have never touched it.
However line out and in ???  Maybe external for an Iphone connection?
It reminds of my BM6000 ('80s) also a plug but a dummy that must be there.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Sat, Sep 21 2013 3:08 AM
It's meant to for the use of an equalizer.
soundproof
Posts 142
Direct LINE OUT which bypasses the internal EQ.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Beobuddy:
If you mean the white plug, you are correct.
It was originally for use with an equaliser which would bypass the on board tone controls.
It serves to join line out to line in and is vital to the use of the Beomaster. Without it you will get no sound at all!
If you get a non-functioning Beomaster, first check that the white plug is present. It will save much time and embarassment!!
Been there and done that.Confused
If you mean the flying lead/socket then I have no idea.
Regards Graham
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Sep 21 2013 7:27 AM
joeyboygolf:
See my post above.
(to all others: I'm sure Leslie is referring to the connector on the right, cut off from view unless you open the picture as he says.)
--mika
liberal
Posts 43
liberal replied on Sat, Sep 21 2013 7:36 AM
The plug on the fly lead to the right was an 'optional accessory' for an external ir receiver  for instances such as  when the 6500 was hidden in a cupboard.
Best,
Paul
nitro2
Posts 34
nitro2 replied on Sat, Sep 21 2013 9:10 AM
Leslie ,
connector for external ir-eye .
The external-bi/dir-eye was an official option , but i never managed to get the proper way to connect it .
Can you please make some pictures of the connections to the processor board .
And there should be one lead going to + power as well .
If you can give me some help maybe i can make mine working too.
nitro2
B&O , ......and some more
Beobuddy
Posts 3,972
Beobuddy replied on Sat, Sep 21 2013 9:49 AM
Can't be difficult to get that working.
But you have to be sure that you have a working ir-receiver which is properly connected on it's own board and then attached the right way.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Sep 21 2013 3:20 PM
Thank you all guys and as Mika mentioned and Graham noticed, the picture has to be fully opened to see the flying lead at the right side of the Beomaster. That was the thing I was talking about.
Brengen & Ophalen
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Sep 21 2013 4:09 PM
Maybe an ir will work, but isn't it the connection to the AV7000 Dolby prologic decoder? To my opinion this is the way to connect this device!
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Sep 21 2013 4:32 PM
Wow, really? I have a AV7000 surround receiver but what's the use connecting BM6500 to AV7000?
Brengen & Ophalen
Dennis
Denmark
Posts 627
I definitely don't think it's for connecting a AV7000! The AV7000 is connected to a BeoMaster/BeoCenter via AUX and PowerLink, if I've understood the user manual correctly:
expoman
Posts 182
Silver Member
expoman replied on Sat, Sep 21 2013 5:26 PM
If you look at the pin layout on the plug it does not match either power link or tape/aux plugs. I am sure it would match the external IR receiver used on the VX 5000.  This was for placing the system in a cabinet where it would not be seen.  That is why it was a option.
dus73
Posts 16
dus73 replied on Sat, Sep 21 2013 9:12 PM
Hi. This is for the ir transmitter/sensor 8087018. Used if you place your bm inside a cupboard or behind Glass Doors.
regards Stephan
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Sep 21 2013 10:14 PM
expoman:
Hmm, I think I must have one of those in my closet....
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
expoman:
Brengen & Ophalen
Steffen
Denmark
Posts 1,408
Steffen replied on Sun, Sep 22 2013 2:10 AM
expoman:
I have one of those external IR receivers for the VX5000 - and it has a Mini Jack plug...
expoman
Posts 182
Silver Member
expoman replied on Sun, Sep 22 2013 3:05 PM
Yes the VX eye used a mini plug. However the MCL 2 eye used this plug. The VX eye lacked the timer function and the LEDs that told you the link or timer was active that this plug supported.
Dillen
Copenhagen / Denmark
Posts 13,191
Millemissen
Flensborg, Denmark
Posts 14,680
Wow - Dillen is the man Smile
js
Posts 382
js replied on Tue, Oct 8 2013 10:10 AM
Very interesting topic as I have a related question.
The plain external IR sensor (if I am not mistaken it was type nr. 2001 that was used, at least for the Beomaster 5500 which had a fixed plug in the socket panel) did not seem to have the "Mute/Standby" button that the similar looking MCL2 sensor had.
Does it mean that it was not possible to activate or to put the system into standby by manually operating the plain external IR sensor connected to Leslie's Beomaster 6500 external plug?
Therefore, instead of the plain IR sensor, would it be possible to connect a MCL2 sensor to Leslie's Beomaster 6500 external plug and to use the "Mute/Standby" button for manual operation?
Many thanks in advance for your help Smile
js
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Oct 8 2013 12:43 PM
An MCL sensor would work as an IR sensor but the Timer and Mute buttons would not. If you look at Martin's installation document, you will see that there are only three connections to the external sensor. These will be ground, power, and IR data.  The Mute and Timer buttons would require extra connectivity.
js
Posts 382
js replied on Tue, Oct 8 2013 2:43 PM
Thank you Guy, this is a very clear answer.  Yes - thumbs up
Page 1 of 1 (28 items) | RSS
