Beogram 4002
LOULOUX
Posts 2
LOULOUX Posted: Wed, Apr 11 2012 7:51 PM
I have a Beogram 4002 which I haven't used for a while and have just rigged it up tonight and the stylus up/down switch isn't working.  Anyone know how to fix this?
Medogsfat
Leeds West Yorkshire
Posts 3,896
Do you mean the stylus won't lower at all? Can you hear the solenoid click when it tries to lower?
If this is the case it is likely to be dried up lubricant on the drop arm solenoid pivot points. They stick solid & need stripping & relubricating.
Medogsfat
Posts 3,896
Medogsfat replied on Wed, Apr 11 2012 8:05 PM
I meant to also add THIS LINK (from the archived "old forum") to my previous post which shows you how to open a Beogrm 4002.
Chris.
LOULOUX
Posts 2
LOULOUX replied on Thu, Apr 12 2012 7:57 PM
Thanks for that and the pictures.  I'll take it apart and have a go this weekend when I get the service manual.  I can hear a click when it tries to lower so hopefully that is the reason.  Probably shouldn't have stored it near a radiator!  Thanks again.
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
