What am I working on now?
This post has 309 Replies | 8 Followers
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie Posted: Fri, Jan 17 2014 9:03 PM
Beolab and master classic 5000 (3 sets)
Glasspanels cleaning and refitting plastic frames
Overhaul of ALL my 4500 systems Stick out tongue
Overhaul of all my Beocenters 9000/9300/9500
Valve amp 608
Beogram 8000 (from Jacques)
SC80 furniture (from Jacques)
To many things I wanna do at the same time.
Here some pics but looooots more to come...
608 circuitboard to be recapped
Beomaster 5000 classic part
Recapping Beomaster 5000 classic
Veneer work for Beomaster classic topcover
Beogram 8000 new plates and dustcover to be repaired.
Almost finished "woodwork" veneer topcover Beomaster 5000 topcover
Glaspanels 4500 systems, Beocenters
Brengen & Ophalen
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Fri, Jan 17 2014 9:11 PM
You must be at great risk of accidentally producing new hybrid Beomasters Leslie!
Graham
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 17 2014 9:15 PM
I'm aware of that GrahamWhistle
Brengen & Ophalen
Jacquesboo
Posts 171
Leslie, I am always impressed by your ability to restore every B&O stuffs that come to you. Sorry for giving you so much work ;)
I'm hearing some jazz with your beomaster 700 right now : perfect moment ;).
See you
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Jan 17 2014 9:57 PM
Thanks Jacques, I'm happy to work on your stuff, some "woodwork", lots of fun!
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 19 2014 6:34 PM
Talking about "woodwork", made an attempt to do my first veneer job for my topcover Beomaster 5000 classic and just finished it.
My BM4400 in full working condition!
No recapping,TLC's or lubrication, just as it is...
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 19 2014 6:37 PM
And I just heard from my techfriend Ipaul that my valve amp 608 is in full working condition. Will post pictures off course.
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 26 2014 6:52 PM
New topplate for Beogram 9500
Beocord 2400 cleaning and polishing
Brengen & Ophalen
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jan 26 2014 7:19 PM
Beautiful work Leslie.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 26 2014 7:44 PM
Thank you "riverstyx"! There's more to comeSmile
Brengen & Ophalen
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jan 26 2014 8:06 PM
I'm curious - what is in the bowl that are you soaking the perspex slider in to clean it?
Kind Regards,
Martin.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 26 2014 8:10 PM
Just ordinary citrus dish soap. Just let it stay in for a day and the acrylic will be bright again!
Brengen & Ophalen
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jan 26 2014 8:38 PM
Leslie:
Good to know - thanks.
As my first vintage restoration project I have recently acquired a circa 1979 Beocentre 4000 which I understand shares most of it's components with the Beomaster 2200 so should be a really nice amplifier once I get it working.
This one will mostly be an electrical / mechanical project as the unit looks to be in good cosmetic condition but I'm keen that my next project will involve more woodwork and metalwork. I'm lucky in that I do a lot of electrical work for a company who specialise in bespoke metalwork and joinery so usually have someone I can turn to for advise regarding joinery, veneers, metal cutting etc.
I was speaking recently to the company that does their laser cutting of sheet metals as I wanted to know about the possibility of laser etching / engraving as I thought this might be a good alternative where the original parts have printed text. If I go down this route I'll be sure to post pictures of the result.
Kind Regards,
Martin.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 26 2014 8:51 PM
Please do, quite curious how you do your restoration work!Yes - thumbs up We can learn from each other, right?
Brengen & Ophalen
pacificocean
Posts 100
Do you need a vintage driving license for recapping these old devices?
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jan 26 2014 9:28 PM
pacificocean:
I learnt to solder, at least to a reasonable standard, way before my legs were long enough to reach the pedals in a car... One of the advantages of repairing the older stuff is that it justifies not using lead-free solder which to my mind has never felt right - it just doesn't flow in the same way although I guess it just comes down to what you are used to.
If I ever reach Leslie's level of ability with the cosmetic repairs I'll feel more than justified in removing the learner plates Smile
Martin.
pacificocean
Posts 100
riverstyx:
pacificocean:
Martin.
I was refering to the 5th picture of Leslie.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 26 2014 9:42 PM
Actually, if you do this kind of "restoration work" a lot of times (and with lots of failures, which I don't show Stick out tongue) you become very handy. Again, I don't have skills in electronics repair but the Beomaster 5000 (caps replacement) was not that difficult to do. I did 3 masters now and they are all workingSurprise
Now the Beolabs 5000's but I need some time to do that...
Brengen & Ophalen
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jan 26 2014 9:46 PM
Ah, I see - I missed that one completely Embarrassed (although I wouldn't have recognised a .nl driving license)
If it is required I probably need to check with my insurer as they only offer 4 weeks european cover per year Wink
Martin.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jan 26 2014 9:57 PM
Leslie:
Yep, and we all make mistakes, some justified, some very silly. I have lost count of the number of times I have spent hours trying to locate the source of a problem, only to come back at another time and instantly spot the cause (or my silly mistake) but this is all part of the learning process and you just try not to make the same mistake a second time.
Today I spent some time making some cabinets to sit in the alcoves either side of my fireplace to hold my set to boxes etc, one was a little deep so I disassembled it, carefully measured and marked how much I needed to trim off each panel, measured again just to make sure, cut the panels and then realised I'd cut the wrong edge off one panel (the finished front edge rather than the unfinished rear edge) Crying
Luckily I had enough offcuts left over to make a replacement panel.
Martin.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 26 2014 9:59 PM
That's what I mean Martin!Big Smile
Brengen & Ophalen
pacificocean
Posts 100
And the license is about the same age as the beomaster. :-)
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Jan 26 2014 10:13 PM
What license are you talking about Hans?Smile
Brengen & Ophalen
pacificocean
Posts 100
I think it is bed time for me I see things that are not there.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Feb 9 2014 1:22 PM
608 tube amp with new tubes, working now! On the search for 4 original knobs..
Beovox RL140's Good Hifi's rings for refoaming, recap and new cloths...
Waiting for Jason's new straps
Making brackets for my Beolab flatpanels..
Brengen & Ophalen
Jacquesboo
Posts 171
Leslie, next time I come to see you, I want to hear this 608 valve amp (last time it was not yet finish ;)) !!! I never heard B&O valve amp (some philips or grundig but never B&O, they seem to be rare here...).
I still do not like RLs too much but seeing you refurbishing them like you do and after seeing and hearing some at your place, finally I'm started to love them ;).
Good job ;).
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Feb 10 2014 8:44 PM
You're welcome my friend. Hope I still have the 608 when you're here. :-)
RL's have a typical shape that you should like but the sound of the 140's is amazing! Just sold another pair...
Brengen & Ophalen
the_o_master
Posts 856
Leslie:
Nice knobs from BEO610 on this BL608 Leslie.
I think you can also try to find Master de Luxe Moderne / Present 608/609 or Grand Prix Moderne / Present 608/609 for spares, they have all this knobs you are looking for.
Talking about knobs: I see you have some spare parts from Beo610. Could you provide me one of those square buttons (concrete On/Off but I think they are all the same)?
I would be very grateful!
Vintage Bang & Olufsen
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Feb 11 2014 7:08 PM
Sure I can, would you like me send one?
Brengen & Ophalen
the_o_master
Posts 856
Leslie:
I thought I was asking for the button of Beo610 :-)
Unfortunately I can not send / provide you buttons for Beolab 608. I have 2 BL608 and also 2 Master de Luxe 608 but I do not have one for spare parts. But if I find something I will let you know for sure.
So do you have the square ON/OFF button  of Beo610 for me?
BEst regards,
Theomaster
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Feb 11 2014 10:29 PM
the_o_master:
Meaning "Would you like me TO send one"?
PM me...
Brengen & Ophalen
the_o_master
Posts 856
Leslie:
PM me...
I did.
Did you get my message?
BR / Theomaster
the_o_master
Posts 856
the_o_master:
Leslie:
PM me...
I did.
BR / Theomaster
Very interesting Leslie.
It is a fourth or fifth time in the last few months that I asked you something here in the forum and you said “PM me”. I always did that and never got any answer from you.
Are you getting my mails? Do you have lot to do or you are simply ignoring me? Unsure
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Feb 14 2014 10:13 PM
Not ignoring you, why should I? Just being lazy, that's all. Get lots of emails. Will come back to you, I'm quite busy for my next trip to Bulgaria...
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Mar 1 2014 1:10 PM
Restoration Beovox cubes project from last year finaly came to an end.
Lots of pictures...
Brengen & Ophalen
Jacquesboo
Posts 171
Ohhhhhhh !!!! They are incredible ! Keep a pair for me ;)
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Mar 8 2014 7:35 PM
Will see Jacques.
In the mean time I finished my SC80 furniture that we have traded, remember?
It was a sunny day so let's go and do some funny work!
Some scratches to get rid off.
Preparing for repainting accessories including stand.
Looks like something is missing here. Jacques, where is it? Oh well, I'll think of somethingWink
Now unboxing the equipment that belongs to this furniture!
Tomorrow connecting all the units to the master.
Brengen & Ophalen
BO
Halmstad, Sweden
Posts 728
BO replied on Sat, Mar 8 2014 9:01 PM
Absolutely amazing!
//Bo.
A long list...
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sun, Mar 9 2014 2:45 AM
Looks great. I enjoyed your pictures of the cabinet apart for cleaning. By this time next week I should have my second SC80 cabinet. Your pictures show me what my goal is for my results :)
-sonavor
sonavor
Posts 3,732
sonavor replied on Sun, Mar 9 2014 2:52 AM
Leslie, are you missing the black metal cover for the cable area of the cabinet? If so, I am sure you can make a replacement. Let me know if you need the dimensions.
-sonavor
Page 1 of 8 (310 items) 1 2 3 4 5 Next > ... Last » | RSS
DigiCert Secured Site Seal
