Hello, thank you for reading this
I've got some kind of a problem
Everything is working fine, but the sound is playing only from the center speaker (beolab 7), in speaker setup everything is set to beolab 5, when i'm in this menu i can hear noise and etc, and the lights are green.
But just after i save my settings, beolab 5 turns down, and the sound playing through the beolab 7 again, and i can do nothing!
Got tireв of learning manuals and exploring the menus, it doesn't work for me at all
If i put the beolab 5 cable instead of beolab 7, it works fine, but as you can guess it works only for one speaker.
Also i have a round remote control (for beolab 5??) but it doesnt glow with green or red, only when i turn to radio mode, but even then the buttons are inactive..
Please help)
Where are you located?
x:________________________
Zermatt, Swiss, why?
Is there something i could do to make it works? or you mean i have to call b&o specialist to manage with this trouble?
And one more correction, when i'd said about connecting beolab 5 instead of beolab 7 i mean i put powerlink cable to center input on beosystem 3, and then it works fine for one speaker...
I really don't know what else to do, i think i'm missing just a little little setup somewhere, but i can't find it, help please...
I can post the photos of settings or connection if you need!
By the circle remote control I meant this thing
But there is no text on mine, and green glows only when in radio mode...
Maybe this is the problem?
Because at my other home i just have to push the green button and my speaker activates and start playing..
arseniyv:And one more correction, when i'd said about connecting beolab 5 instead of beolab 7 i mean i put powerlink cable to center input on beosystem 3, and then it works fine for one speaker... I really don't know what else to do, i think i'm missing just a little little setup somewhere, but i can't find it, help please... I can post the photos of settings or connection if you need!
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
