Last night i decided to try and set up my Apple TV with my Beovision10. I already had a ATV gen1 set up (from when i first bought the TV), but wanted to upgrade to the gen 3 ATV.
Anyway, i unplugged he PS3 swapped the HDMI over to the ATV, moved the IR sensor and turned it all on... TV working, Apple working, controller not working... no surprise, but i start playing with the controller and intuitive it is NOT!!
Bottom line - I deleted my old ATV control, plus my Sonos setup (which was under camera), the controller wont work the ATV and the only upside is i can still select the ATV and my virgin media.
I have searched the internet and can't find a guide that explains how to program a function to operate a 3rd part system. I can add buttons, but how do i get those buttons to control the ATV. I will also at some point want to set up a button that will select the composite input and then work the PS3.
Help appreciated!
