Streaming "Airplay" from Mac to Beolab 8000 and Beolab 3500
This post has 2 Replies | 2 Followers
Bittermann Hans Jörg
Graz, Austria
Posts 6
Bittermann Hans Jörg Posted: Fri, Mar 7 2014 11:25 AM
Is there a good solution available for that ??
Audio: Beocenter 7000 + Beovox S45, Beocenter 9500 + Beogramm 9500 +Beolab 4500 + Beolab 8000, 2x Beolab 3500, Beovox CX50, Beolit 12
Video: Beovision 5500, Beovision MX 6000, Beovision MX 4002, Beocenter 1
Remote controller: Beolink 1000, 2x Beolink 5000, 3x Beo 4
Link room: Beolab active
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Mar 7 2014 11:55 AM
Assuming you have the speakers in a Masterlink system, the best way is to get an Audio Master (e.g. Beosound 3000, 9000 etc) and connect a Playmaker to the setup.
You will then be able to Airplay to the Playmaker, and pickup the sound in any linkroom.
If you skip the BL3500, you can connect the playmaker to the BL8000 and do not need an Audio Master.
/C
Millemissen
Flensborg, Denmark
Posts 14,680
You'll need a BeoMaster with a free A.AUX-port (or a A.TAPE-port).
Connect the BL8000 to it and MasterLink the BL3500.
Note: in case of A.AUX the software of the BL3500 must support the A.AUX-commando!
Connect an AirPlay-receiver (AirPort Express, Playmaker, Arcam airDAC....) to the BeoMaster.
There you go Smile
Another solution:
Connect one AirPlay-receiver to the BL8000. You'll need adapter cables for that.
And another one to the BL3500 via the 'Almando Masterplay':
almando.com/index.php/almando-category/masterplay-masterlink-konverter/almando-masterplay.html?___store=default&___from_store=endkunde_eng
This way you can adress them individually Big Smile
Greetings Millemissen
Page 1 of 1 (3 items) | RSS
