The BeoSound Essence listed
This post has 250 Replies | 5 Followers
BeoBoy68
Alsace ๐Ÿ‡จ๐Ÿ‡ต
Posts 1,247
BeoBoy68 Posted: Sat, Mar 8 2014 4:55 AM
Finally, the BeoSound Essence is listed.
Prices in Euro:
Ref. 2990 - BeoSound Essence - white box + 1 remote control - Euro 795.-
Ref. 1715 - 1 additional remote control - Euro 150.-
I will order it to change my (ugly) Playmaker. Stick out tongue
Millemissen
Flensborg, Denmark
Posts 14,680
Is the 'hide-away-box' prettier/less ugly?
StUrrock
Posts 995
Any news on the beomusic app?
Chris Townsend
Qatar
Posts 3,531
On behalf of many others i'm sure, what does it do`?
Millemissen
Flensborg, Denmark
Posts 14,680
If you mean: what does the 'BeoMusic' app do? - the answer is: that is the piece of software (on a tablet) that feeds and/or controls the Essence-box.
The 'knob' is just for the essencial simple, everyday controlling, such as start/stop, skip and volume control.
That could - theoretically - be left away - especially if B&O would choose to activate the ir-support of the box (means use your Beo4 instead).
Chris Townsend
Qatar
Posts 3,531
Thank you, and good morning.
StUrrock
Posts 995
StUrrock replied on Sat, Mar 8 2014 11:56 AM
Millemissen:
So we could do away with the pointless knob and have pointless ir control instead?
Are these are pointless ad ons when an app could do everything, or am I missing something?
Chris Townsend
Qatar
Posts 3,531
The knob although overkill, might not be so stupid after all.
I've just bought the mighty A9. I use my mini IPad to stream to it, but the volume control by the IPad is very agricultural. One notch up seems to increase volume by a lot.
I tried my A8 controller and it works. It's far easier to change tracks and the volume is much more accurate and smooth. Our new labrador has made "modifications" to it so I need a new knob(I had to say that) where can I get one?
Millemissen
Flensborg, Denmark
Posts 14,680
Somehow it (the 'box') must be 'feed' - through AirPlay, DLNA, Spotify (connect version) and the built-in Internet Radio stations must managed.
For that you need an interface = the BeoMusic app. But any AirPlay or DLNA app or the Spotify app could be that to some extend.
You could even turn up and down the volumen via the app - if the remote-'knob' is not at hand.
But the point of the Essence remote 'knob' is, that if 'the box' has been 'feed' (with a Spotify playlist or a list of preferred radiostations) you just need the 'knob' for everyday-control. Turn it on (to the last played playlist/radi station..., skip to next track/station..., turn the volumen up and down and finally turn off the good thing.
And that is probably all that most people need!
But you will have to have the app to initially 'feed' it - or if you often change the source during the day.
Ir-support is 'for future use' - and just mean that you would be able to do the same with the Beo4 as with the 'knob'.
Besides - for those who don't already have a Beo4, the 'knob' will be a cheaper remote than the Beo4 -and will be all you need for the essential remote-controlling of the Essence-box.
This way the 'knob' does make sense - and is a cool looking/eyecatching device as well!
StUrrock
Posts 995
Millemissen:
I just hope B&O's vision is not routed in 1980s thinking as you just describe, otherwise Essence is doomed before it's released!
This hit a button to carry on playing what was last paused is perfect if you live on your own.
In a family situation it is just useless, no matter how beautiful the wheel looks!
Millemissen
Flensborg, Denmark
Posts 14,680
Living together is always a challenge, isn't it!
Who is in charge of the music?
Who has the device with the app?
Kids usually listen on their own - don't bother about them.
You will have to agree with your partner, what to listen to.
If you can't, just buy two Essence's Stick out tongue
Any other suggestion for a solution?
Mark
London
Posts 1,063
Mark replied on Sun, Mar 9 2014 10:34 AM
Agree with the knob action, I use my 4 on my Beolit 12 as the iPhone & iPhone volume controls are just too clunky. It would be good to see the "master knob" control sound levels on all my systems including TV.
Millemissen
Flensborg, Denmark
Posts 14,680
Won't be - the 'knob' works with a bluetooth connection to the Essence box.
BeoBoy68
Alsace ๐Ÿ‡จ๐Ÿ‡ต
Posts 1,247
@Mark
Agree with you
@Millemissen
What a shame !
Millemissen
Flensborg, Denmark
Posts 14,680
Waiting for a Beo4 Mini - Stick out tongue
Mark
London
Posts 1,063
Mark replied on Sun, Mar 9 2014 4:46 PM
MM will it be called Petit Fours :-)
Millemissen
Flensborg, Denmark
Posts 14,680
LOL
StUrrock
Posts 995
Millemissen:
Oh dear, oh dear, oh dear........
If B&O have the same rationale, they will go down the pan.
Millemissen
Flensborg, Denmark
Posts 14,680
Getting ready to sell lots of Essence-sets - I hear Unsure
DoubleU
Posts 562
DoubleU replied on Mon, Mar 10 2014 6:44 AM
Millemissen:
Just guessing here, but to me this IR-support would only be useful if the Essence is setup with a fixed PL-out, and connected to the AUX of an existing BeoSound. The IR-knob will wake up the Essence, not via ir- or rf-command, since it’s wired, and will first send an A.AUX command via IR, to the BeoSound. Volume+/- also only via IR to the BeoSound.
StUrrock:
So the RADIO button on a beo4 is also useless, since it does exactly the same. What kind of magic do you want to happen with a single knob?
Millemissen
Flensborg, Denmark
Posts 14,680
If the Essence-box would be connected to a A.Aux of a BeoSound (being in fixed line-out), you wouldn't need the ir-support at all - the 'box' would be controlled by the app, and the volumen from the BeoSound.
That is - if it acts just like the Playmaker does (which I assume).
Adding ir-support would only mean, that you could control it with the Beo4 directly - just like you can control the Playmaker in the (default)  standalone-setup.
Whether the ir-supprt will come or not, is not known - but since they have included a port for an ir-receiver, you might think that it sooner or later does.
If in this case the 'knob' will continue to work, is a good question.
I guess it won't be long 'till we have the answers.
StUrrock
Posts 995
StUrrock replied on Mon, Mar 10 2014 3:39 PM
DoubleU:
In an increasing amount of situations I find today, the answer is yes.
Millemissen
Flensborg, Denmark
Posts 14,680
Please leave us - at least - the 'red dot button' on the Beo4 Crying
BeoBoy68
Alsace ๐Ÿ‡จ๐Ÿ‡ต
Posts 1,247
BeoBoy68 replied on Wed, Mar 12 2014 2:56 PM
12.03.2014
The application BeoSet Up include today the New BeoSound Essence !
vlohjr1
Posts 553
vlohjr1 replied on Thu, Mar 13 2014 8:43 AM
Does anybody know whether the essence is dual band? Thanks
Vince
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Mar 13 2014 10:04 PM
Millemissen:
Official launch is supposed to be 1 April.
Millemissen
Flensborg, Denmark
Posts 14,680
1. April - LOL
The dealer I spoke to today did not know anything.
On the ther hand - the Essence is now part of the updatet BeoSetup app!
BeoBoy68
Alsace ๐Ÿ‡จ๐Ÿ‡ต
Posts 1,247
BeoBoy68 replied on Thu, Mar 13 2014 10:36 PM
Moxxey have maybe right ! The first April is Tuesday ! It will be cool ! I order allready mine with 2 nice aluminium remote control. Happy to throw in the recycled trash my playmaker already defective.
Millemissen
Flensborg, Denmark
Posts 14,680
Why would you think that the Essence would be better (apart from the N.Radio and Spotify Connect support) than the Playmaker?
badgersurf
Posts 539
badgersurf replied on Fri, Mar 14 2014 10:03 AM
I managed to pop into a dealer and managed to read throughthe "Beosound Essence Ge t Strated Pack" which they had left on the desk while he went to make a coffee.
The section that caught my eye was "Custustomers who own a beosound/ beomaster"
Beosound essence is the easy way to extend the functionality of old audio systems - the hideaway box can be connected to the AUX port of the existing system and the Beosound Essence remote can be used in IR mode for directly controlling an existing Beosound / Beomaster System"
had to quickly take a picture on my phone of this one bit before they spotted me as they said I was not allowed to take it away it was staff only and they should not be showing me it until launch So you didn't get the above information from me Wink
Mark
London
Posts 1,063
Mark replied on Fri, Mar 14 2014 12:24 PM
badgersurf:
Now that is interesting
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Mar 14 2014 12:54 PM
badgersurf:
Interesting that they mention "Beosound Essence remote can be used in IR mode" and "controlling an existing Beosound/Beomaster System".
Does that mean that the Essence remotes will be able to control my Beocenter 2 when I play e.g. CD:s? That way the Essence would make sense to me. I would get the Spotify Connect functionality. I would get a cool remote for the majority of the interaction with my music system. I could replace my Playmaker with something (hopefully) more robust.
/C
BeoBoy68
Alsace ๐Ÿ‡จ๐Ÿ‡ต
Posts 1,247
BeoBoy68 replied on Fri, Mar 14 2014 1:33 PM
@Millemissen
You have the answer by Badgersurf above.
The essence will have certainly better electronic component and his design is so much better. The beautiful wheel is separate and more functional.
The hideaway box reminds me the socket unit from the BeoCenter 2 in compact size (designed by David Lewis).
All reasons to forget the ugliest audio product ever made by B&O: the Playmaker.
Millemissen
Flensborg, Denmark
Posts 14,680
The 'knob' is nothing more than a remote, a controller with very limited functions.
if it should control a BS2 (or any other BeoMaster) it should/would have a ir-sender in addition to rhe bluetooth-sender (I can hardly believe that). And it would only control 'skip', 'turn off/on' and the volumen anyway.
The essential part of the Essence is the 'hide-away box' - period!
If you look at the 'hide-away box', you will see a port for a ir-receiver - so I should think that it is the other way round: the 'box' can (in addition to the app (BeoMusic) be controlled buy a Beo4.
At least I think so, untill you can convince me otherweise Stick out tongue
That the Essence-box can be connected to a 'AUX' is nothing new - I have written that many times on the forum. That is exactly what I (and others) do with the Playmaker - which by the way is hidden away.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Fri, Mar 14 2014 4:07 PM
Millemissen:
Well, while I for one don't hate the looks of the Playmaker as some do, I have mine in a cabinet, set to not respond to IR if it gets any accidentally, and with a fixed volume output, run into the Aux In on my BS9000, so I'm right with you on how I use it.
It seems that the people they aimed the Essence at are ones who are very playlist oriented. I'm not, I often listen to a playlist, but usually I select individual albums and play thru them. I guess in that way my old fashioned roots from the dark ages of hifi when albums were it are showing...
Jeff
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Fri, Mar 14 2014 4:33 PM
Mark:
badgersurf:
But it would have to have the capability of turning off the Beomaster as well to make any sense.
Graham
Millemissen
Flensborg, Denmark
Posts 14,680
Jeff:
Everything is 'playlist oriented' nowadays - the trend is to consume playlists from everyone else, from the (so called) friends on the 'social network', what Spotify or your internet provider recommends you, 'the topten-playlist' , a 'running-playlist or one for studying......
Listening to music has become passive, just like listening to a mainstream radio station.
The Essence is the ideal sound system for that kind of listening.
But that won't fool me - I would use it (if I should upgrade from my Playmaker to it) exactly the way, that it pleases me.
Like you, I prefer to listen to an album from the start 'till the end.
---- In some way an album is a playlist, that an artist made at a certain point of his carreer/life. ----
Any streaming device can be used for album listening - it just depends on how you use the device.
I can't imagine listening to muaic without my Playmaker anymore - though I still use my cd-player relatively often.
I don't consider myself as oldfashioned - pretty much music is produced as an 'album' even today.
P.S. I can't say that I am in love with the looks of the Playmaker, but I definitely don't hate it either - not at all.
It is just a piece of hardware, that does it's job - (apart from the music) the important thing is my iPad and the Beo4 controlling my BeoMaster.
If the Essence 'knob' makes people buy more 'boxes', it was a good decition to make it that way - I don't need it.
DoubleU
Posts 562
DoubleU replied on Fri, Mar 14 2014 10:16 PM
Millemissen:
You can also add the BeoMusic app. Three different sources, no 3rd-party DLNA app, no conversions for Airplay, so no unnecessary battery drain from your device, and not the least, not depending from AirPlay with the occasional wifi dropouts Just play straight from the source, all built-in in one app. I would say these are huge upgrades in comparison with the PM.
Millemissen:
Maybe you’re right, but to me very unlikely. In most cases it would be a random guess to change the music you're listening to. This is not simplicity at all and not very B&O-ish. And nowhere it is confirmed the IR-port is for a receiver as you assume..
vikinger:
Still guessing here, but it would all make sense if the port 'for future use' will be used to send commands, but only to toggle an A.AUX command to a BeoMaster/Beovision, and at the same time wake up the Essence where you left off last time. Why not benefit from the fact that B&O’s IR-commands don’t have to be aimed to an ir-eye, so you can place the remote anywhere in the room. So in combination with a Beomaster, the Essence will still do as advertised:
"Great sound instantly. Just touch".
mbee
Paris, France
Posts 1,842
mbee replied on Fri, Mar 14 2014 10:24 PM
@Millemissen :
I think that if badger surf is correct, B&O implemented the IR in the opposite way you are thinking :
1. Turn your Essence in IR mode
2. That makes your Essence "fixed volume", because it is connected to the Aux of a Beosound/center
3. The "IR port" of the hideaway box is not for a receiver, but its an emitter, so that the hideaway box can send the source/play-stop/next/previous/vol+/Vol- commands from the Bluetooth remote to your Beosound/center.
It's simple, it should work and it's a whole new way to control old systems...
vikinger
Posts 5,422
vikinger replied on Fri, Mar 14 2014 10:41 PM
I was thinking about the control of Beomasters evidently much older than those in mind in this thread!
I control my 40 year old Beomaster 2000 with one of those energy saving extension leads that has an IR sensor. The beomaster has a Roku type web radio unit connected to its tape input. When the remote is used to turn off the Roku unit the IR signal simultaneously switches off the power to the Beomaster. An IR switched power controller is needed to make the best use of beomasters that were not originally intended for remote control.
Using vintage equipment with the convenience of remote control requires creative thinking..... we can't expect B&O to cater for their ancient but superb designs.
Graham
Page 1 of 7 (251 items) 1 2 3 4 5 Next > ... Last ยป | RSS
