Hi forum.
I bought a pair of S45-2 new in 1980, and now I want to put them to good use again after they were standing in the loft.
I read that there's a risk that some old glue will fail, causing the magnet to drop, and thereby bending/damaging the voicecoil.
What could/should I do to prevent this?
NOTE: I'm not able to tick the Question option above.
Kind regards,
Rune
Hi
I would be tempted to try them out first, then maybe look at this thread for some inspiration ;¬)
Craig
Keiths Woofers - (beoworld.org)
Rune8600:What could/should I do to prevent this?
https://archivedforum2.beoworld.org/forums/p/47445/340071.aspx#340071
Thanks a lot to both of you - I will now take out the woofers, clean the area where the epoxy will be, and apply the latter.
