Beocenter 7000 feedback
This post has 3 Replies | 0 Followers
bigphil
Posts 69
Silver Member
bigphil Posted: Sun, Sep 21 2014 1:25 AM
Hi just set up my very nice 1980 Beocenter 7000. Everything's as it should apart from when I use the Phono there is a terrible low hum as I increase the volume. I have the stereo on an original cabinet with the speakers either side. I have the speakers quite close to the unit as it looks very nice. Is there anything I could use to stop this? Thanks Phil
Die_Bogener
Posts 192
Remove the speakers from the cabinet, maybe it's a resonance problem causing a feedback loop?
Or put the Phono on a very heavy stone platter...
But more probably: the motor of the phono is going defect, running not smooth any more... touch the platter/case or directly the motor itself. Maybe the humming comes from the motor ... mechanical problem with the motor or the power supply of the motor. 50Hz power supply humming? Try a new cap parallel to the motor.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Sep 21 2014 3:13 PM
Transport screws losened ?
bigphil
Posts 69
Silver Member
bigphil replied on Tue, Mar 31 2015 2:49 PM
Late reply.... Which ones are the transport screws and how tight are they supposed to be? Cheers Phil
Page 1 of 1 (4 items) | RSS
